Hook repair/replace on Watchmaster MS winder
MrRoundel
Greetings. Does anyone have any ideas as to whether that hook is replaceable? The other size of winder (Watch-craft) has the hook, and it is incorporated into a ring that is set into a recess. I have my doubts that it's fixable, but it would be nice if it were, as the other winder is made for probably 16-18s pocket-watches, and I'd like to use it for smaller ones. Thanks for any ideas. Cheers.
Edited by MrRoundel
Add brand.
I take it that I'm rather stuffed on this one. Oh well...I did think that I might, if I had the skill, drill crosswise through the shaft at the recess, and insert a pin. Anything else I can think of would seem to tend to spin i the recess, making it unworkable. So if any of you machining experts can suggest a drilling technique, I'm all eyes. Thanks.
Thanks khunter. I don't have the tools or skills required for drilling a hole so small. I have other winders, it's just this Watch-craft is a nice one where it's a shame for it to be incomplete. I bought it at an NAWCC Mart quite a few years ago, but didn't know to check out whether the hooks were intact. Let that be a lesson to me and anyone who reads this. I do find it odd that it would get broken, but someone found a way. Cheers.
Thanks, vinn3. Coincidentally, I just picked up a Foredom tool that has a drill-bit/Jacobs style chuck. I guess I could use that. And I have a Unimat lathe that has a Jacobs chuck. I won it in a raffle at an NAWCC Mart a little over one year ago. Which do you think would be better for drilling this part? I guess I have to figure out how to hold the tool while it's drilled. I've looked around for tutorials on using that lathe, but I can't find any for the beginner, which I am. Thanks again.
BTW: The Unimat has the capability to setup  to be used as a drill-press. And it even has a machine-clamp that will probably work to hold it steady. I forgot about that. I'll have to convert it and see how it looks. That should solve my "holding" problem. I suppose it's about time I used the tool for something. Thanks, vinn3. Cheers.
7 hours ago, vinn3 said:
  the early unimats had a  1/2 x 20 inch thread,
The Unimat db200/SL1000 had a 12mm spindle thread and the U3 a 14mm spindle thread.  afaik that was universal.  A deviation would be a be big deal as accessories wouldn't fit - where did you come across a unimat with 1/2 spindle thread?
have one.  must be a "made in U.S.A."   ,   thing.   I sometimes use a Jacobs chuck in place of a "unomat"  4 law.  vin
I don't think they were ever made in the Us, Unimats were made in Austria.  12mm is close to 1/2 but I think you'll find its 12mm.   1/2 20 would be slightly large, It would be a loose fit with 1/2 20 and the register part of the spindle wouldn't register.   Try a 1/2 20 bolt in the 4 jaw, it should be very tight or more likely won't go
Edited by measuretwice
Of the two Jacobs chucks that came with my lathe, only one fits the spindle threads. One is a Rigid brand, which may have come from a drill motor; It does not fit, FWIW. I set up the Unimat SL1000 for drilling with the machine "vice" to hold the part to be drilled. The drill bit will have to get between the barely open jaws in order to do the work. It will be tight but looks doable. I won't be able to get to the actual drilling for a week or so, but will report back on how it works out. Cheers, gents.
thats a very capable little machine that you can do a lot with and have a lot of fun with, nice raffle prize!
Take khunters advice and locate the hole with a very small punch mark.  Drills generally need a place to start - punch or spot drill.  Especially true on cross drilling as the round surface makes it very easy for the drill to deflect off to the side
    • It's pronounced "bombay" like the city.  French for bomb is, 😄, bombe, pronounced the same as in English. Bombé, bombe.
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
    • I have quite a few watch brands from all over the world. For some reason this Timex electric from 1979 is capturing my attention this week. I am not a particularly fond of battery operated watches or Timex, but this one is different for some reason. Post your watch in your collection that seems to draw you in more now than before...
