Lathing long narrow objects
Titanium
Lately I’ve been trying to make pins for a strap and to do this I need to lathe a bit of metal down to 1.3mm wide and it has to be 20mm long. To do this I place a live centre at the non-chuck end then slowly lathe the rod down. The problem I’m having is the diameter of each end can be up to 0.12mm thinner than the middle. I’m using an Emco Unimat 3 to do the work.
Is there a way to get better results or is it a difficult thing to do?
6 hours ago, Titanium said:
.. each end can be up to 0.12mm thinner than the middle. I’m using an Emco Unimat 3 to do the work.
Such a thin and long piece will definitely flex with any significant tool pressure. You could try with an extremely sharp cutter (so not some carbide insert), or with a very sharp hand graver. Or try to stone/sand the 0.12 mm center error away..
There are many ways to come at this.  Easiest is to machine it in sections, like oldhippy suggests, have a little sticking out of the chuck, machine some, pull more out etc.  Sort of a manual Swiss lathe :) (with a swiss lathe tool stays still and the material advanced out of the chuck).
Does your lathe have collets or just the three jaw?  I don't think too many of those had collets so if its just the three jaw, carefully maintain the same radial position of the material - this will minimize the affect of scroll error as you reset the position.
You can get a less than a perfect finish this way but there is a neat toolmakers trick for that.  take two pieces of wood and glue some fine emery to them - roughing maybe 600 or 1000 grit, then 2000 grit.  Ideally flat little slips of hardwood, but two popsicle sticks might work (better if its harder).  pinch them over the revolving work, abrasive side to the work obviously, and bring to size.  Unlike holding the abrasive cloth by hand, the firm backing gives some control an makes it possible to end up with a reasonable good and smooth cylinder.  Make sure you protect the bed with paper towel, any abrasive paper gives off lots crap you don't want on the ways.  Now if you're ever called upon to make 1mm taper lap you know how lol
This is a good tip. I guess I could put the wood in a vice and that should give me better control.
I have a weird ER chuck for the Unimat that attaches to the spindle but it does not normal ER16 collets properly. I think it's for ESX 16 collet which are apparently ever so slightly different. Today I ordered this collet chuck so I'm looking forward to using that. I'm still trying stuff. I'll report back if I find a good way of doing this.
9f3a1a3e-957a-4b13-88c8-a76e00d54e49_600
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
