Strange Lathe Thread
jdrichard
13 hours ago, jdrichard said:
Last note: picked up a nut today and it fit perfect. Need to cut it and compress it a bit. Still confused as i don’t think it is an acme thread
This is not it an acme thread.   There is no reason to think it was and lots to think it wasn't, but proof positive is that the metric nut fit perfectly.
Why do you need to cut it and want to compress it?   imo this is fruitless exercise; describe what are you trying to achieve and if I can I'll be glad to describe how to get there....but imo its not going to be through the plastic deformation of a nut.
The Lathe requires a nut that stays in place once it is snugged up against the tail stock spindle. The other lathe nuts i am trying to emulate all have a slot that you use to do the final adjustment of the nut. It goes on a bit snug. So i want the nut to be snug and to do this the nut that i purchased needs to be compressed a bit. So i plan on grinding it down to reduce its length, cutting the slot and then , perhaps, heating it and compressing it.
Use two nuts, tighten them against each other - lock nuts.  afaik that is the OEM set up for that machine.   I mentioned it before - you don't like that approach?   For lots of reasons I think trying  plastic deformation of the nut will be a problem and have not seen a machine put together that way.
Edited by measuretwice
Good job. You see either split nuts like this, or alternatively pairs of nuts with one acting as a lock-nut as measuretwice suggests.
The latter is commonly used for cup/cone bearings on bike hubs and on older headsets. It’s worth mentioning that tightening the locknut with the other held static actually pushes the static nut further. Presumably as the threads are compressed closer together.
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
