Tools for cutting dials
Mattaphysics
Yeah... Obviously out of my price range. But I know you can just buy enameled dials but the problem is finding something to punch holes and windows for other complications. Would a staking set accomplish this? Then you can also just paint it yourself of course. Has anyone done this and is it feasible?
No, the staking set is for delicate, low force work. They use an impact press for that at the factory. However you can cut any shape with a small drill bit and a piercing saw.
Ok so is there a special tool or just find a drill bit (I know there are special watchmakers drills but not sure what bits to get) then, obviously have a template to ensure correctness, saw the shape out and buff any burrs.
Ok thought, what about one of those mini electric drill/engravers and use that to cut like for instance a day/date window or a hole for a complication? It's that possible or will it damage the dial?
Drilling is done just to insert the saw blade, so any size will do.
You should learn do things by hand first, like in the good old times. Most DIY electric tools are not for watch work, because as mentioned watches require much more precise and delicate work.
3 hours ago, Mattaphysics said:
Ok then, what exactly am I looking for? I searched for mini saw, precision hand saw and nothing that I could use. What is the saw used for that? I apologise for taking the touch over it wasn't intended just one thing after another.
Check: https://www.cousinsuk.com/category/saws-blades-frames-fret-piercing
I'm sure that your hardware store has something similar.
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
