Hamilton Electric 14K Nautilus 200
wetbird
Interested in knowing, if paying out $350 for the repair of this watch would be practical. An estimate valve (to a collector) would help me make a decision about having the restoration preformed. Any estimates of the value would be appreciated.
Thank you.
Thank you.
imageproxy.php?img=&key=77f0dcc5ac0f9d5b
Pictures are required please.
Thank you.
That imageproxy link doesn't seem to be working.
J
Thank you.
While I'm no expert on this type of watch, I do think that this is the best-looking model of the Nautilus watches. It also appears to be the first one, made in 1963. There's a book by Rene Rondeau, "Watch of the Future", that is all about the Hamilton Electrics. It contains images of what might be all of the Nautilus line. That it is a 14K example, and in what looks like excellent condition, I'd say it might be worth it. Is the back gold as well, or is it stainless steel? I don't know that there is a huge demand for these right now, but it might picking up, being that they are examples of the fashionable mid-century styles.
A check of Ebay might be your best bet for figuring a market value for this watch.
Working on electric watches seems to be a rather in-demand specialty. I happen to be working on my first one now. Fortunately, I have the service manual. Otherwise I'd be more doomed towards failure. I'm almost through reassembling. Fingers crossed. Good luck.
Edited by MrRoundel
Correct Typo
While asking if paying out $350 to get this watch repaired is practical , is something you would have to decide  for yourself .  It is probably the first Nautilus electric , being of the 200 series , and it is 14K solid gold , [a Big Plus ] , and it is in great looking shape . The Solid gold Hamilton Electrics Do hold their value .
  Having said that , I have a few Hamilton electrics in my collection and I have made repairs and serviced both the 500 and 505 movements . The later 505 movement is by far easier  to repair and service , and most Nautilus watches had that movement  . The 500 is tricky to repair because of the proper and delicate alignment of the 2 contact fingers .
  I would suggest that you get as much Information on the type of movement in your watch and contact members of the Hamilton Forum with questions as dadistic suggests .
Also you may want to contact Ebay seller adamtime with any questions . He always has all things Hamilton Electric for sale .
adamtime (758)
100% positive feedback
In the past I have emailed Hamilton Electric Guru , Rene Rondeau  through his website with questions , and he is a gracious Gentleman that will answer your questions .
Good Luck Wetbird  , and let us know what your outcome is .
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
