Need crystal for Casio wave ceptor
Dweib
Help please. Discovered a small scratch approx. 4.5mm long at the 12:00 position on the crystal that I could feel with a finger nail. I tried to remove it with a dremel and felt polishing tip with a dab of polishing compound but only made it worse. So I am now in search of a replacement crystal. Your help with a link is appreciated. Movement is 5110. Watch is WVA-M650D- 1A2JF. I would consider sapphire if it's not unreasonably priced.
Looks like it's a flat crystal, so you can use a generic. I suggest that you bring it to a good watch shop (where they change batteries and do minor repairs) for replacement. They will measure it and if they can't, you can order one yourself for about $1. Sapphire can be around 10 - 15.
Crystal measures 34mm installed. Ordered a watch press set from ebay. Youtube videos show careful removal and replacement looks straight forward. I'd like to do this myself. But need to know where to order the crystal once I remove and measure it.
Thanks I will register with them and order one of their generic flat sapphires after I remove this old one. Not sure of the size yet but I see I can get a 34.1 x 1.0mm sapphire crystal for approx. $27 US plus shipping. Sounds like the plan.
Ordered a 34 x 1 mm flat sapphire from Esslinger. They are fairly close to me right across Lake Michigan. Should have it within the week. Will post again after install.
sent via htc one m9
sent via htc one m9
They already shipped! That was quick within an hour of placing the order. Regardless the damaged crystal is rather inconspicuous now. And you have to hold it at a certain angle to really see it. But I know it's there. So I'll change it.
sent via htc one m9
The sapphire crystal arrived and I must say I'm am not all that impressed with it. It just a flat piece of blah glass. The original mineral glass has a very slight curve to it. So I decided to try rubbing a bit more with that diamond paste. Went by hand using q-tip, paper towel and a few dabs of the heavier 28 micron stuff. It took several hours of hard rubbing but now all the scratches are gone and that depression in the center is just barely felt. Followed up with some finer grades and used .5 micron as a final polish. I'm happy with this and am thinking about not changing the crystal after all.
5dab3b3d2cd723e5dc64c61017ea560d.jpg&key=703740ef61cb805f6fb366858a8424ff4e66b7cd8235a7ed284e2ea14a385ad9
sent via htc one m9
Which is why using a rotary tool on a felt wheel is advisable.
Not if your in-experienced doing so. The reason it took several hours of hard rubbing was not for the original scratch (easily removed several days ago) but for removing the dimples and marks caused by improper use of the rotary tool and felt wheel. I tried the dremel method twice as shown in the esslinger and other videos and both times I apparently applied too much pressure with not enough movement and the friction overheated the wheel on the crystal causing a dimple and tiny score marks. Suggest recommending novices practice the technique on something other than a good watch first.
sent via htc one m9
I think you were spinning the dremel too fast. In fact, these starting at 3,000 rpm are already too fast for polishing, not too mention buffing. A regular drill actually works better.
Quote
It's always good to learn on a throw away watch. Just like paying attention to what one is doing, and not blame others for own's failures.
  • jdm locked this topic
  • jdm unlocked this topic
Agreed. I have an old '70's Timex that's pretty scratched up. I'll see what I can do. But I believe it's an acrylic crystal so I wonder if a rotary tool would be appropriate?
sent via htc one m9
sent via htc one m9
It's very easy to over do and overheat acrylic with a rotary tool. If I'm going to bother polishing plastic, I do it by hand. Mostly I just replace acrylic, I have a good inventory of round crystals and huge piles of various specialized plastic crystals for vintage watches. Then it becomes a matter of digging through the mountain for the right one :-)
Ah.. makes me wonder if the crystal I've been working on above is actually acrylic. Kinda feels like plastic.
I may contact you if the old Timex needs a new one.
sent via htc one m9
No it's not, as mentioned crystal would overheat immediately and be ruined. Isn't even necessary to use diamond paste with these, any fine abrasive compound will work.
Yeah, I love this watch and won't give it up for nothin'. Perfect size, full featured, light weight, solar powered, syncs every night at 12:04, easy to read digital stop watch, secondary time set to Greenwich UTC, 5 alarms, has a light but the lume is bright and easily visible all night long clear to my alarm time of 5:45. WVA-M650D-1A2JF
sent via htc one m9
At this angle you can clearly see the dimple that is still in the crystal. But it's usually not very noticeable. And not seen in the last two pics above. So I won't change it just yet. Dimple was caused by improper use of a dremel and polishing wheel.
Edited by Dweib
I want to know why the devil this $200 watch scratched so easily. I've been wearing a cheap $40 K&S autowind at my machinist job for several months and not get a scratch on it but the moment I wear this Casio for just one day the crystal scratches up?
My bet is that is is not mineral glass, but some sort of hard acrylic. A dremel won't dimple mineral glass that quick. I've polished several old mineral glass crystals (pocket watch size) with a dremel and never made a mark like that, and if it scratches that easily, it also makes me lean towards some sort of acrylic.
I agree with you. That is my opinion as well. Although the specs claim mineral glass.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
