Economical watch tools (again)
oldhippy
7 minutes ago, oldhippy said:
When it comes to horological tools the trade is flooded with foreign imports of inferior quality.
No doubt but since there are economical tools which do their job perfectly, our duty is to inform about these. No generalizations please.
I recommend to members on here of the type of tools I have used which I think is justified. I am not going to advise people of tools I have never used. Watchmakers/repairers on other forums, do not recommend cheap imports.
Absolutely, see all my postings mention type and purchase place of the tools that I use.
On 16-3-2018 at 2:15 AM, Deggsie said:
Is there a chat section entitled "Freedom of Speech In the Western World" and one about "Why I fought For my Country's Ideals"?  Meant light heartedly JDM, but we are only "chatting".
jdm just pointed out to discuss it in the correct section,...I agree with him...keeping it on topic
I have many Chinese and foreign tools. Cheap and cheerful screwdrivers, Tweezers, movement holders etc. All re-engineered by myself and all are very good at little cost. If the tools are prepared correctly for the work then the rest  is mainly down to the skill and know how of the repairer. Just my opinion. It is my understanding that a lot of Chinese manufactured components are used by a large movement maker and it is not unknown nowadays for expensive watches to be 1st. class air mail insured and shipped to China for service/repair if one knows where to go in China for this work. The sender then triples the cost to his customer.
On ‎3‎/‎13‎/‎2018 at 6:46 AM, rodabod said:
Just remembered: I bought a Chinese Katsu Mini Pillar Drill recently and it’s incredibly good. Virtually no play, and a very clever design using a sewing machine motor.
Interested in info on this please...
On topic:
I have a (Chinese?) crystal press. I used it as such once- it is fine but the dies, with their brass inserts, are worth less than dental floss at a Willie Nelson concert. The brass works loose and scored the crystal.
I have re-purposed it however. Using the correct dies, it is the absolute best way to remove (Aluminum) inserts from Rolex bezels without inflicting any damage to the inserts. It's also good at reinstalling them. Rolex crystals don't really need a press- only the crystal retaining ring. Formerly I have used a 12-point socket and a drill press to set them. However, I plan to make a dedicated tool, with the exact angle of the retainer, to set them properly. (it's on the list!)
I also have (knockoff) Rolex case back sockets which work very well. "Ruihua" brand, with a hand-wheel wrench. They will fit the "fancy" press tools but I have only one caseback that I can't remove with this tool. It's a Titanium case with a Titanium back. REALLY stupid since Titanium LOVES to gall and I think that's exactly what happened (or it's cross-threaded but back it sitting flush). It should have a stainless back. Anyway, that will be getting a liquid oxygen bath to shrink the back away from the mid case and it WILL come off...
I think I have some knock-off plastic tweezers too. Those are fine for holding a battery. The "Faux" Dumont tweezers are absolute garbage however. I have one pair I was burned on and they would not even make a good clothespin...
Very sound advice but I bought a small expensive screwdriver that was right out of line two years ago and have seen "experts" using similar ones on video  that wobble around, would not do for me.  Many tools have to be re-engineered in my humble opinion.
Some only. For example my Anchor drivers are fine, so are the Vetus tweezers. But the bench type case opener needed a little bit of work to clean some screws. So all cases are different, but on both I got noo big names, small cost, excellent performance.
Me too and all agreed.
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
    • Hello Wai and welcome to the forum. A little information to enlighten you a little more TZIllustratedGlossary.pdf
    • I am certainly not the first one who happen to ruin the chronograph center-wheel of a Seiko 6139B. The internet, when you search for it, is littered with stories, even here on WRT there are some. One of the problems is that the service manual of the 6139A is readily available on the net, not so with the service manual of the 6139B. On top, reading other forums & stories, there are people who claim that there is hardly any difference between the 6139A and the 6139B movement, so the 6139A service manual will suffice. However, one of the crucial differences is the design of the chronograph center-wheel. Also the Seiko reference numbers are different. For the 6139A, the reference number for the chronograph center-wheel is 888610 and for the 6139B: 888611 or 888612, depending on which manual you are reading (and perhaps there is a difference between these two wheel too !??) To lubricated the 6139A chronograph center-wheel, the following graphic picture in the 6139A service manual is given; One has to press down the sprocket and oil it. Unaware of the difference in chrono center-wheel design, I pressed down on the sprocket, but there was no movement. Perhaps not understanding or interpreting the drawing correctly, I pressed with the tweezers on the 4th wheel. This caused the 4th wheel, which turned out to be a press fit to the sprocket by the 6139B, to strip off the sprocket. Thereby me joining the line of all the others, who tried this before and are now searching for "how to fix" this misfortune. In an older thread on WRT, member @ricardopalamino place a picture in which he shows the difference in center-wheel design between the 6139A and the 6139B. To the left the 6139B and to the right the 6139A. As can be seen on the left center-wheel, the 4th wheel is pressed onto a sprocket. Pressing down on it, as shown in the 6139A service manual, gives a ruinous result. People did several attempts to repair the damage, but so far, I haven't found a success story. Here is one of the attempts; Reading what already has been tried, I tried a different approach ..... but sadly failed too. Nevertheless, I'll show what I've done; perhaps somebody may fine-tune or expand on the idea and has success? In my staking set was an anvil with a 4.5mm hole, exact the size needed to fit the chrono center-wheel "up-side-down". The distance between the clutch parts and the 4th wheel was 0.25mm. To support the 4th wheel as close as possible up to its center, I used feeler gauge blades, on one side a 0.25mm blade, and on the other side a combination of 0.15mm + 0.10mm blades. This allowed me to tap the sprocket back onto the 4th wheel ...... The thickness of 0.25 blades doesn't prevent some "spring" action, and so my 4th wheel was slightly deformed. The re-attachment seemed successful, but when trying to true the wheel, the connection failed again 😭 Currently there is a NOS 6139B chronograph center-wheel on eBay. Last Sunday the price was €150, on Monday the seller increased the price to €165 !!         Prevention is better than the cure and I do hope that anyone in the future, searching for a 6139 manual, with read my "Warning". As for my Seiko, I'm not going to invest €165 for one part and since the rest is pretty good, I will sell the watch for "parts or repair" 😞
    • Off the top of my head I can't remember which was which, but one of the hands had the clutch with the very fine radial teeth as described above, the other had a flat disc with two tiny 'pins', there was what looked like the remains of something black smeared on the opposite face, maybe the remains of rotted rubber? When I can get some good pictures of both I will post
