Referendum - Any Thoughts?
I don't normally talk about politics on forums - too much danger of tempers being raised - but I just wondered if anyone had any comments on the whole business. I didn't mind a result one way or the other, meself, though I didn't think all the ramifications of a "yes" vote had been thoroughly thought out.
I note that the first "Yes" response came from Dundee... I hope Geo's still talking to us!
I have to say that, many years ago, one strand of my ancestors - the Ballingall family - came from Kinross.
Lots of people in the NE of England have Scottish ancestry, my grandfather on my mothers side was a proud Scot from Dumfries. When it came to the push Scots, Welsh, Irish and English all fought side by side and would not have hesitated to die for each other. Like many Nations with shared borders there will always be some problems as History shows, but when it comes down to it despite differences past and present I feel we all belong together but should also not be afraid to be proud of our differing cultures.
History never looks good in hindsight ;).
If Ireland were still part of the Union, I suspect a vote in 2014 would be similarly divided. There's already a hint of panic when anyone brings up the notion of the UK exited the EU. That reminds me, can we borrow your Queen again? I really enjoyed watching the poor Sinn Feiners last time around ;).
Edited by PadraicB
I think it's a shame No failed, not because I'd have liked to see the Scots go, but because I saw it as an anti-Westminster (all parties) vote. It would have been nice for the politicians to get an inkling of how much they are loathed and that this might have consequences. I expect an independent Scotland would have managed fine—there are plenty of small (population) countries in Europe and they mostly do pretty well for themselves.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
