Angelus 240
Hi Guys,
It has been a while since I have been able to post.  I currently have an Angelus 240 movement on my bench.  I have managed to fix a few of the  issues with it but it still suffers from a keyless works issue.  I believe that the pilot hole where the stem enters the mainplate has become worn, as is the hole for the hub of the stem.  The pilot hole itself doesn't look enlarged.  Just worn from the end of the square turning against the plate.  The hole for the hub has worn so much that the set lever doesn't hold the stem when it is pulled to set the time.  I was wondering what the best route would be to fix the movement.  I have attached a couple of pictures and will try to upload a video showing the play in the mainplate.  Thanks in advance for any advice and help!!!
Edited by omgiv
Thanks guys for the help.  I am not overly familiar with this movement and finding genuine parts is rather difficult.  I did a comparison shot of the stem I have to the one oldhippy posted and it does indeed look different.  I will try to see if I can find a reliable genuine stem before doing anything drastic.  Thanks for the advice!
Thought I would just give you guys and update and thank you for the help.  I was able to find a new stem and the new stem does indeed work.  The only problem was the threads were larger than the crown I had.  My gauge stops at 1.20mm so I am guessing the stem was 1.40mm.  The crown I have accepted 1.20mm stems.  I cut down the stem on my lathe and rethreaded it.  Thank you again for all of the help!!!!
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
