Platax tool on Ebay
Andyclient
1 hour ago, clockboy said:
The problem with it, is it has no punches and the punches are not available anymore.
Yes, I did see that after the fact but something about waiting x number of seconds before posting again kept me from posting "Oops, nevermind".  :mellow:
  • 2 years later...
