Screwdrivers Choices
I have been using A&F screwdrivers for a few years and only recently purchased some Horotec. However the Horotec I shape the tips (see pic) using their sharper which gives a better grip on most screws. So I now have two sets the A&F & Horotec.
In my option the A&F are really good screwdrivers they just need dressing now & again.
58ca4259e3dd9_ScreenShot2017-03-16at07_41_42.png.40ad5a56bff97204ab9af1aea697df1b.png
I love the US based vendors like ofrei, and esslinger but do shop around. It has been cheaper for me to order from abroad and have it expedited to the USA. Usually it saves me anywhere from $100-200. Which makes me think our supply houses here are quite inflated with pricing.
Eternaltools.com has some horotec screwdrivers. And they are a wonderful vendor.
https://www.eternaltools.com/watchmakers-screwdrivers/horotec-9-watchmakers-screwdrivers-set
As a beginner, so far I'm very happy with Starrett's S-555-7 jewelers screwdriver set.  I like the collets they employ for securing the tips, which are readily available through MSC Industrial Supply.  While they may benefit from a mild dressing here and there, the leverage is good right out of the box and the hexagonal heads prevent them from rolling.  They are sized in inches, but I've yet to be let down by that.
Clockboy, the Horotec Sharpener would be Ideal for dressing up all my screwdrivers...I just might get that tool as well.
thanks!
Federico, thanks for the link they seem to be of decent price and I really like the sharpener Clockboy mention to keep the blades dressed up.
Wesley881, I've heard of these before are they based in the USA? They seem well constructed.
3 minutes ago, clockboy said:
I use both styles. Some of the smaller screws still require the normal shaped headed screwdrivers. I have noticed that some suppliers now sell the Horotech shaped blades see below : However you still need the sharper to dress them.
https://www.cousinsuk.com/product/flat-parallel-bergeon-7895
Thats pretty neat, I think I'm going to save up a little extra and get the Horotec screwdrivers and sharpener so that i wont have to worry about it later. Also Do the Horotec screwdrivers come standard with the T-shaped blades?
Hi madchops67, They are US-based and you can get replacements online from MSC industrial supply. I had to dress one of the tips up so far, but that's part of it. Lots of strength, even on the .025".
Sent from my SM-G920V using Tapatalk
They come with standard shaped blades. If my memory serves me well I had to dress them anyway to a normal wedge shape. But later I changed their shape when I purchased the Horotec sharper.
  • 5 months later...
On Saturday, November 21, 2015 at 9:10 PM, bosstaki said:
Hi bosstaki,
How do you feel for both Horotec and VOH? quality, weight balanced, etc.
I am always know VOH is over-top but I wish to know more about comparing them in term feeling and quality since they look about the same but different so much in pricing. Hope if you could share some of your experience.
Hi bosstaki,
Hi I can't see the reply post of you. Is there any setting problem?
Hi Ste, there’s not much difference mate between the VOH & HOROTEC mate, they both have the same feel with good grip, they’ve both got the same blue steel finished blades which are ground to perfection, the only difference between both is the horotec has a different roller bearing in the top which you can just see through the tiny hole in the top & the voh has a small black sleeve at the top! They both twist as smooth as silk, like I said mate I had to buy the 250 horotec driver to make up my set mate, I couldn’t find a voh 250 anywhere mate, so I could say I’ve got the best of both, which there both superb!
There is a vid on youtube about the VOH & the guy purchased one on from eBay but it appears to have been a copy or second. So my advice is purchase from a reputable seller.  I purchased horotec screwdrivers last year & also purchased their sharpner that gives a T shaped head. The VOH also look to be a very good screwdriver as well & their complete boxed set looks to be good value.
  • 5 months later...
Hello!
I am interested in a stainless steel handle screwdriver set. I oscilate between Bergeon 30081 and Horotec MSA 01.201.
Self lubricating vs ballbearing :)
Thank you!
Bogdan
Edited by matabog
I also have the Horotec Ministand MSA 01.201-D set of screwdrivers and really love them.
When ever other people in my class see them for the first time they also give them favorable comments.
Since buying the set I have bought 2 more of Hortec's screwdrivers, one size bigger for pocket watches, and one size smaller for the screws on hairspring studs
    • Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares
    • Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
