Screwdrivers Choices
I have been using A&F screwdrivers for a few years and only recently purchased some Horotec. However the Horotec I shape the tips (see pic) using their sharper which gives a better grip on most screws. So I now have two sets the A&F & Horotec.
In my option the A&F are really good screwdrivers they just need dressing now & again.
58ca4259e3dd9_ScreenShot2017-03-16at07_41_42.png.40ad5a56bff97204ab9af1aea697df1b.png
I love the US based vendors like ofrei, and esslinger but do shop around. It has been cheaper for me to order from abroad and have it expedited to the USA. Usually it saves me anywhere from $100-200. Which makes me think our supply houses here are quite inflated with pricing.
Eternaltools.com has some horotec screwdrivers. And they are a wonderful vendor.
https://www.eternaltools.com/watchmakers-screwdrivers/horotec-9-watchmakers-screwdrivers-set
As a beginner, so far I'm very happy with Starrett's S-555-7 jewelers screwdriver set.  I like the collets they employ for securing the tips, which are readily available through MSC Industrial Supply.  While they may benefit from a mild dressing here and there, the leverage is good right out of the box and the hexagonal heads prevent them from rolling.  They are sized in inches, but I've yet to be let down by that.
Clockboy, the Horotec Sharpener would be Ideal for dressing up all my screwdrivers...I just might get that tool as well.
thanks!
Federico, thanks for the link they seem to be of decent price and I really like the sharpener Clockboy mention to keep the blades dressed up.
Wesley881, I've heard of these before are they based in the USA? They seem well constructed.
3 minutes ago, clockboy said:
I use both styles. Some of the smaller screws still require the normal shaped headed screwdrivers. I have noticed that some suppliers now sell the Horotech shaped blades see below : However you still need the sharper to dress them.
https://www.cousinsuk.com/product/flat-parallel-bergeon-7895
Thats pretty neat, I think I'm going to save up a little extra and get the Horotec screwdrivers and sharpener so that i wont have to worry about it later. Also Do the Horotec screwdrivers come standard with the T-shaped blades?
Hi madchops67, They are US-based and you can get replacements online from MSC industrial supply. I had to dress one of the tips up so far, but that's part of it. Lots of strength, even on the .025".
Sent from my SM-G920V using Tapatalk
They come with standard shaped blades. If my memory serves me well I had to dress them anyway to a normal wedge shape. But later I changed their shape when I purchased the Horotec sharper.
  • 5 months later...
On Saturday, November 21, 2015 at 9:10 PM, bosstaki said:
Hi bosstaki,
How do you feel for both Horotec and VOH? quality, weight balanced, etc.
I am always know VOH is over-top but I wish to know more about comparing them in term feeling and quality since they look about the same but different so much in pricing. Hope if you could share some of your experience.
Hi bosstaki,
Hi I can't see the reply post of you. Is there any setting problem?
Hi Ste, there’s not much difference mate between the VOH & HOROTEC mate, they both have the same feel with good grip, they’ve both got the same blue steel finished blades which are ground to perfection, the only difference between both is the horotec has a different roller bearing in the top which you can just see through the tiny hole in the top & the voh has a small black sleeve at the top! They both twist as smooth as silk, like I said mate I had to buy the 250 horotec driver to make up my set mate, I couldn’t find a voh 250 anywhere mate, so I could say I’ve got the best of both, which there both superb!
There is a vid on youtube about the VOH & the guy purchased one on from eBay but it appears to have been a copy or second. So my advice is purchase from a reputable seller.  I purchased horotec screwdrivers last year & also purchased their sharpner that gives a T shaped head. The VOH also look to be a very good screwdriver as well & their complete boxed set looks to be good value.
  • 5 months later...
Hello!
I am interested in a stainless steel handle screwdriver set. I oscilate between Bergeon 30081 and Horotec MSA 01.201.
Self lubricating vs ballbearing :)
Thank you!
Bogdan
Edited by matabog
I also have the Horotec Ministand MSA 01.201-D set of screwdrivers and really love them.
When ever other people in my class see them for the first time they also give them favorable comments.
Since buying the set I have bought 2 more of Hortec's screwdrivers, one size bigger for pocket watches, and one size smaller for the screws on hairspring studs
    • I don't know if there is a timing machine for balance spring clocks. If not it is a case of trial and error. You should make a note of the position of the regulate and work from there.
    • I'm sure you will get help on here soon.  Kkramme we like new members to make an introduction before posting. A little about your self such as where you life and what got you interested in Horology
    • I'd be grateful for recommendations of good sources of advice on getting clocks with balance spring - as opposed to pendulum - escapements 'in beat'.....
    • Well I am in a bit of a quandary. I can't find the correct colour for the dial. I even wrote to Hettich a while back hoping they would give me the colour code for the dial. The reply that I received was "We don't make those anymore." I am thinking now to silver the dial and use a water transfer decal to put minute markers and the HETTICH logo (which is the very font that this forum uses) and the Made in Germany down the bottom. Not sure of the success rate of the water transfer method, but I have no other solution for the markers and logo. Handpainting is just not an option. In trying to get the top piece of the clock polished, it has progressively lost its sharp edges. My stupid hamfisted effort. I am thinking of purchasing a replacement piece of brass and drilling new holes in it for the corner posts. Why I attempted to repolish using wet & dry and not simply using a paint remover to remove the old lacquer from the brass, I don't know. You whistle and I'll point at the idiot. I also need to purchase some sheet spring steel as the two small ratchet springs that arrest the wheel that supports the weight after it is lifted by the electromagnet are worn. The two from the donor clock that I purchased are worse. I am hoping that I will be able to manufacture new springs without having to fiddle about with tempering etc to the steel. I have some ideas on that front. How many things until the clock is no longer the original? Like an axe. Heard a woodchopper on tv once saying that he had replaced the head on his axe twice and the handle three times, but it was the same axe that he began woodchopping with. 😉 I must post more often or read back through what I have previously written. Keep repeating myself. Sigh.
    • I use the exact OD and it fits in with a little force and a pleasing 'click' so it's snug and wont rotate within the holder, but that depends on how you have set up and calibrated your printer so you may need to play with the settings/dimensions a little to allow for any discrepancies in your printer calibration. PS I just finished (2 days ago) a new revision which automatically prints the movement OD on the bottom of the holder, I'll see if I can upload it here Here is rev 4 remember to change the .pdf to .FCStd so it will open in FreeCAD - also you may need to install the LiberationSansBold font and tell FreeCAD where it lives on your PC, or change the font to something you already have on your system. Para Movement Holder V4.pdf Examples below:
