Lubricants
I have used 941 on low beat movements many times.  I read that it is advised to epilame the pallet stones and escape wheel when using this oil which I have always done.  This probably because it is very thin and likely to migrate more.  That is why epilame is advised.  Epilame is also known as Moebius Fixodrop.  I gather the 9451 is more like a thixotropic loose grease that stiffens up when the pallet stones hit the escape wheel teeth.  It will probably stay in place better at the higher speeds of the escapement parts.
OOPS!  Brain malfunction !!
Should have said that when the pallet stones/escape wheel teeth hit the loose grease in the working zone it reduces the viscosity making it much thinner. When the working zone ends the loose grease will thicken again to help 'stay-in-place' properties.  Makes more sense this way !!!!
Pallet stones should not be greased. Not clock pallets or watch pallets, don’t know about quartz movements.
Moebius 9415 is a lubricant specifically designed for pallets and is recommended for both mechanical clock and watch movements.
It is a thixotropic fluid which means that under static conditions it has a relatively high viscosity which, as Canthus has pointed out helps it to stay in place, but which stressed in some way (for instance when suddenly squeezed between a pallet stone and an escape wheel tooth) becomes momentarily much less viscous allowing it to flow more easily (thus lubrication the interface between the pallet stone and the escape wheel tooth).
It is technically a grease and as such it is perfectly acceptable (even recommended) to lubricate both clock and watch pallet stones with a grease so long as it is 9415 or some equivalent. It would however be entirely inappropriate to do so using something like Castrol LM:biggrin:
If you want to stick with Moebius use  clock oil 8031.
I always preferred JD Windles Clock Oil for all clocks apart from clocks that had a platform escapement, then it would be a watch oil but not too thin.
I'm currently working on a Waltham Hunter which someone has flooded with something that looks like some kind of all-purpose household oil. The watch needs a new mainspring so I'm waiting for it to arrive before I clean and lube the watch. I am wondering if I can use the same oils/grease as a 6497 as I have experience with that type. Any advice would be helpful...
Better explanation from Marc, thanks.  Being ex oil industrial oils 'a grease is a grease' to me no matter what form it takes, so I may have misled some people in my explanation.
Don't know what 6497 is, but 9415 is very thin and may have limited use.
For those interested I have attached Moebius' sales spec book which describes all their oils (at the time of publishing, may be more products now), typical applications and some handy movement/lubes pics.
moebius-specsbook.pdf
  • 5 months later...
I have to say the oil side of watch repair makes me smile. Back in November  put in an order
for a 55 gallon drum of 1000 weight steam oil for my traction engine. I buy about one drum a year and it lasts well.
Two weeks ago I ordered most of the oils I thought I would need for watch repair, the total quantity came to about 14ml
of oil. I paid a third of the cost of my 55gallons on the watch oils. After the panic had subsided I realised that the
14ml of oil would probably last me most of the rest of my life. Seemed a cheap hobby after that!
Merry Christmas to you all!
  • Like 5
This subject has been posted many times. However watch lubricant lasts a long time and 14ml will lubricate many, many watches.
Don't worry somebody will probably invent a steam watch..... Maybe not!
18 hours ago, vinn3 said:
very interesting ! steam locomotives and steam tractors.  did they have an oil that could withstand high temp. steam?  the Lear corporation tried to re introduce the steam automobile.   it failed from piston cylinder oiling.  vin
Most of the big oil producers/blenders still make steam cylinder oil. You want the oil to be easily carried over with the steam.
Steam oil comes in three weights (Common weights) 400, 600, and 1000. The 400 is good with lower pressure engines (150psi boiler)
the 600 works well in engines with boiler pressures around the 200psi. The 1000 is regarded as being an oil for super heated steam.
That said I use the 1000 in my wet steam 200psi engine.
Have a look at the Stanley steam cars, will open any ones eyes as to how well steam can be used.
Merry christmas.
I'm servicing my first pocket watch, it a 7 jewel Waltham.
I already own Moebius 9415 I use on faster beating watches, can I get away on using that on a slower beating pocket watch, or should I buy Moebius 941 too?
Also being this is only a 7 jewel movement the pallet fork pivots are not jeweled. Normally you would not oil these pivots, but I was wondering on a larger non jeweled watch like this if I should oil them and if so should I just use 9020 like I have for the rest of the pivots on the pocket watch, or would I be better to use 9010?
Also on a pocket watch balance end stones am I better using 9020 or 9010?
Pocket watches are a new territory to me.
Thanks
According to the BHI’s practical guide to lubrication, pallet pivot jewels under 13”’ are never lubricated. There is some debate about wheter to oil them on larger movements, but if you do then it’s the absolute minimum of 9010.
If you look around, you will see old moebius oiling charts which recommend 9010 or 8000 on pallet jewels - presumably since 941/9415 didn’t exist then. I have read that 9415 will work perfectly fine on slower escapements and therefore I have only this and not 941. Take your pick if you’d rather use 9010, but I’d use the 9415.
Balance jewels is 9010 all the way up to alarm clocks.
I have M941 but every service sheet I look at seems to  recommend pre-treating the stones and escape wheel teeth with epilame (Mobeus Fixodrop) to stop the very thin M941 spreading.   This does not seem to be required for M9415 as it is a thixotropic grease type oil (ie is goes very fluid only under pressure).  I understand M9451 is now acceptable in low beat escapements.   When my M941 is used up I will change to M9415.
Edited by canthus
First let me say I know absolutely nothing.  However, I'm reading The Watch Repairer's Manual by Henry B. Fried, 1973 edition.  In his second chapter on watch cleaning he says you need three types of lubricants:  Fine watch oil for the train and escapement pivots, clock oil for the mainspring and white vaseline for the winding mechanism.  The dust cover describes Mr. Fried as "our most eminent living horologist".  Apparently he was alive in 1973.  I'm guessing that this was the state of the art regarding lubrication in 1973.  Since he recommends cleaning and lubrication every 9 t0 12 months I don't think he is talking about synthetic watch oil.
I hear that - need the ability to buy a couple of drops at a time - to top it off a lot of these oils have shelf lives!
1 hour ago, GeorgeClarkson said:
Hi I have seen on the bay someone selling "reconditioned" oils, are they any good? what exactly goes into the process of "reconditioning"?
Please post the link. I can only suppose that's a way to sell "expired" oils.
This topic is now closed to further replies.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
