Lubricants
9 hours ago, bobm12 said:
Roger, you can also use some mixture of 9010 and something else...(I've seen this somewhere), you let evaporate and voila! Cheaper and probably a good substitute.
Cheers,
Bob
That is what i am doing now: Just serviced a Seiko 8305 and was reading on watchbloke .http://thewatchbloke.co.uk/2015/09/12/seiko-8306-8020/#more-3799  he had trouble with the lubrication of the reverse wheel in the Seiko. So there it's better to use the 9010 . I am more thinking of the ETA movements.
And o my god there are so many parts in the Seiko 8305 :)
Got a Roskopf second version pocket watch (pin pallet escapement) a few days ago. It has really big parts compared to my earlier repairs (seagull ST-6, DG2813, EB1197..). It has brass holes and jewel end stones at the balance. More weird is the rest of the train; brass holes in the main plate and jewel holes on the bridges up to the escape wheel. The rest has brass bushings. Temporarily applied 9020 in all places up to the escape wheel and after shaping the broken balance spring it is ticking well.
The mainspring barrel (~2 cm in diameter :biggrin: ) is just like a new one, pretty clean, no sign of wear nor grey lubricant. I think i wont touch that, leave it as is.
The main question is, what and where to apply after the overhaul for a movement with such big parts and strange "jewels"? I have 9010, 9020, D-5 and something unidentified oil from a local watchmaker, possibly Moebius 8000.
Hi SZ,
This is my take on this based on what you have:
9020 is "great for the oscillating weights and other moving components of automatic watches. Can also be used on the pivots of center wheels and barrel arbors." according to Otto Frei so I would assume it would do good also on the arbor of your movement and other parts that do a lot of "effort".
You also have D-5 which according to the same source it works on the gear train, barrel-arbor, steel/steel frictions-partners.
9010 is more like a general thin oil for parts that need to move fast or have no "pressure/effort"...I don't know if I'm explaining it right.
From the same source as above I got this: Moebius Classical Oil "8000" can be used on pallet stones and pins for 5 to 8 3/4 ligne movements. Moebius Classical Oil "8000" is also recommended for 5 to 8 3/4 ligne Escape Wheels (Moebius 941), Balance Staff (replaces Moebius 9010), Center Wheel (replaces Moebius 9020 Moebius Classical Oil "8000" ),, use Moebius Classical Oil "8000" on the Wheel Train (replaces Moebius 9010 ), Barrel Arbors (replaces Moebius 9020), , use Moebius Classical Oil "8000" on the pallet pins found on 9 3/4 all the way up to Pocket Watch Movements, Moebius Classical Oil "8000" can also be used on Escape Wheels and Balance Staffs 9 3/4 ligne to 19 ligne movements. Moebius Classical Oil "8000" can be used on the Center Wheel, Wheel Train and Barrrel Arbors of 9 3/4 ligne all the way up to Large clocks in place of Moebius 8141."
I would say you need something like a Moebius 8200 family of oils or maybe 8300 family according to use and material of the barrel.
This is MHO since I'm not familiar with your movement.
Cheers,
Bob
Hi SZ,
Cheers,
Bob
Great advice. I will be assembling the Seiko Chrono 6309 tomorrow and don't want to screw it up. I also have a few old pocket watches that need lubing. If the pocket watch seems tight when you wind it, do you think it is a gummed up main spring ? The crown just does not turn easily, but does turn. Is this normal or do I need to get out the oil gun:)
14 hours ago, bobm12 said:
Bob
Thank you for your efforts and time!
Well, finally applied Li based oil for the keyless and up to the barrel arbor, since i have only one drop of each fine oil. 9020 to the 2 wheels nest the barrel and 9010 for the escape wheel up to the balance. Running fine laied dowm with around 180-200 degrees amplitude according the mark on the balance. Although, its getting slower on the side, below 120 degrees. This was not the case before service. It had around 140-160 degrees amplitude in all positions. I will try thicker oil on the balance pivots if it wont get better after 1-2 days of running.
During the service i noticed that it has only 3 jewels :). First i tought that both balance pinions are cap-jewelled but the one in the plate is a simple steel plate. So You suggesting maybe D-5 here is better? And the one in the escape wheel is cracked. Maybe a thicker one here till i find a replacement jewel?
@jdrichardHonestly, IMHO, JD, I would take apart that pocket watch and give it a complete maintenance. In the end, yes, you will have to use your "oil gun"! But first clean and inspect. I believe the treatment of the mainspring is a little different from the autos since that one doesn't slip. So, maybe 8200 is in order on the spring and the barrel goes dry?. Also, you would normally use thicker oils for "bigger" movements....depending on how big is that pocket watch.
As far as the Seiko, anything you do for the 7S26 will probably do the trick on that one. Lawson has an excellent walkthrough about this 7S26 and the post talks about oils too. You probably can use D5 instead of the Seiko S-6 and some graphite based 8300 series or even 8200 series grease instead of the S-4 for the barrel as long as it is breaking grease (the actual mainspring I like to clean and lubricate with 8200 so the coils slip among themselves, not on the barrel walls). I would try and get Moebius 941 or 9415 for the pallets though in a pinch you can still use 9010. NOTE:S-4 or S-6 I'm always confused which one is the black one...which is the graphite based one that goes in the barrel so please change the above accordingly if I mixed them up! :)
@szbaloghSZ, I think you are doing just great. The amplitude thing could also be a weak mainspring. Some jewels may actually take D5 while others will take 9010 depending on the work they do. If speed is needed (balance, etc) 9010 is indicated. If force rather than speed is needed, D5 may be the one you want. The idea is to "create" a "soft" bushing with the oil. Too thin an oil will break when parts are transmitting force (power train?) Too much oil will slow down the movement when too much is applied specially in sections where speed is necessary. A thicker or a more "staying" grease is beneficial when on the keyless works since you want it to stay (like everywhere in the watch regardless) but they are usually rubbing hard so you also want a smooth "action".
All that said, I would inspect carefully the hairspring to determine if the low amplitude is due to oil or dirt contamination, magnetism or simply too much oil (or too little, or misplaced) on the pivots. Check the state of the jewels in the balance and its pivots too...rust could be also a reason when localized there. Regretfully I can't observe you watch, much as I would like to, so this is the general way I would approach this problem. Is this helping any?
Cheers, guys and good luck, keep me in the loop,
Bob
As far as the Seiko, anything you do for the 7S26 will probably do the trick on that one. Lawson has an excellent walkthrough about this 7S26 and the post talks about oils too. You probably can use D5 instead of the Seiko S-6 and some graphite based 8300 series or even 8200 series grease instead of the S-4 for the barrel as long as it is breaking grease (the actual mainspring I like to clean and lubricate with 8200 so the coils slip among themselves, not on the barrel walls). I would try and get Moebius 941 or 9415 for the pallets though in a pinch you can still use 9010. NOTE:S-4 or S-6 I'm always confused which one is the black one...which is the graphite based one that goes in the barrel so please change the above accordingly if I mixed them up! [emoji4]
Bob
Bob, the Seiko is a 6309 movement. I am reading and learning from all your advise, thanks.
Thank you JD,
Here is the tech data:
6309A.pdf
You can use moly grease in place of the Seiko Watch Oil S-2 and HP 1000 instead of S-6. The "V" and the "A" oils could be the same 9010. Sorry the pdf is not in color! :)
As I said before, you can treat this movement almost as a 7S26 for oiling purposes.
Cheers,
Bob
Thank you JD,
6309A.pdf
You can use moly grease in place of the Seiko Watch Oil S-2 and HP 1000 instead of S-6. The "V" and the "A" oils could be the same 9010. Sorry the pdf is not in color! [emoji4]
Cheers,
Bob
Thanks Bob
3 hours ago, bobm12 said:
Bob
Yes, great help! Thank You!
The impulse "pin" is a simple shaped steel plate engaging the pin lever which is also steel. Stripped down and D-5 is now here. Changed to D-5 in the cracked jewel too. It may be slower but will last longer. There was to much oil on the excape wheel teeth (steel on steel since pin lever escapement), which congregated on the first pin in a big drop. Washed down and added just enough.
Balance also trued to some extent, i dont have calippers but much better now.
Beat error also carefully corrected (see picture).
True, the hairspring is also faulty, it was entangled when cam to me. But ~200 degrees is respectable considering the 100 year age :) Actually, the amplitude seems higher now.
Cant measure the accuracy right now since the 17280 bph speed. No one application can handle it. But from the calculations from the wave sample it is ~80 s/hour slower. Have to play with the hairspring a bit.
OK I have been following this thread for sometime now loosely. Would I be correct in summarizing that basically, if you plan to work on more than one style, or one brand of watch, one must have approximate 50-100 different types of oils on hand that may or may not ever be needed? Or Moebius 8000 in a pinch.....
I'd say D-5 or the Hp equivalent would be handy, mcass, also 9010 is a "defacto standard", a mainspring grease is also a good thing to have and of course, some moly and the 9415 for the pallets...I guess that would sum it all...unless the movements are bigger or much smaller than usual....then maybe one more type of oil accordingly...I personally have many types at hand and once in a while buy another, different type just in case. I've have had need of them all at some point (by following the tech sheets) although I realize I could have made do with just the basic 3 or 4.
The HP line of Moebius has a longer shelf life and perform better than the natural oils but they are much more expensive...it is all a matter of "preference" to put is one way.
Cheers,
Bob
8 hours ago, jdrichard said:
What is this program you are using?
From Canada
Its a simple wave editor. Just measuring elapsed time between beats. Colored numbers were put therein Windows Paint :)
I managed to get the loss down to 7.7 min/day.
Thank you JD,
6309A.pdf
Cheers,
Bob
The manual calls for S4. I thought I could use D5 as an equivalent?
As a rule of thumb. Thicker pivots use D5, thinner pivots use 9010. If it moves slow, D5, moves fast 9010. Automatics/smaller watches I lean towards more 9010. Big watches like pocketwatches get D5 everywhere except the escape wheel.
Did you guys ever sort where to buy them? When I bought mine, I got tiny "sampler" sized bottles from a french ebay store, like $10-20 each, and they've lasted me years.
Sorry for the double post. But this is where I got my oils http://www.ebay.com/itm/Oil-Grease-lubricants-Moebius-swiss-made-to-choose-for-watchmakers-chronograph-/151144554717?var=&hash=item2330eae0dd:m:mar9MRBQY0dSFs-N1enHVHw
Was the cheapest/smallest quantity I could find anywhere. And I have no affiliation with this store, if there is an issue mods feel free to delete my post.
  • 4 weeks later...
Hey, gang. Would these be acceptable Novostar substitutes for Moebius?:
Novostar B for 9010
Novostar L for 9415
Novostar R for D5
Novostar Mainspring Grease for 8200
Also, while I have you on the line: Up to now I have been using Moebius 8000 for just about everything. I know this isn't ideal, but what is 8000 generally used for? Thansk!
Attached is a Novostar Lubrication chart it also has the Moebius equivalents.
One of the things I've always found interesting about Novostar Lubrication Is the rather confusing description of where you should use it. If you look at the chart it looks like Novostar B Is just about the universal oil for everything in the watch?
Novostar oil.pdf
This topic is now closed to further replies.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
