Lubricants
Well I would definitely start with Moebius 9010 (for train wheels and balance endstones) and 9020 (for train wheels) if you are working on Pocket Watches.
Moebius 9415 is a must for Pallet/Escape wheel teeth.
A quality silicon grease.
Moebius D5 is essential (barrel arbor, motion work).
Molycote DX or Moebius 9501 grease for keyless work.
Moebius 9501 or 9504 for high friction (e.g. Cannon pinion, Setting lever spring and anything at high friction).
Moebius 8200 grease for mainspring. Moebius 8217 for barrel wall (automatic watches)
It's a lot but at a minimum get 9010, 9415, D5 and 8200
I hope this helps.
Recommended Lubricants for Getting Started.pdf
Moebius_Oil_Chart.pdf
  • Like 25
About a year ago when I was just starting to get a bit serious about starting this hobby I bought one of those cheap watch repair kits. I have since replaced all the crap in there with quality versions of what they were supposed to be. My question relating to this topic is this little tube of oil in the kit. Is this just more junk from the kit or does it have any purpose or can it be used in place of any of Marks suggestions? Seems VERY light and my feeling is that the trash can is its new place.
I would not trust it. The last thing you want is for oil to spread out of where it is intended to be.
Its probably still good for some things though. I use cheap clock oil for lubricating my tools like my lathe, the threads on pin vices etc.
  • 2 months later...
I have watched the video on how to service a 2824 movement. I have movement here that I would like to service, but I have a question about the oils.
In the video, (Mark's video on youtube) he says to use Moebius 9010, 9415, and D5. I am a real amateur and I have to buy all the tools and oils to do this. My question is if there are any oils which I can substitute in place of these to use as a cost savings, or If I haveto go with the Moebius oils.
Any help would be greatly appreciated. Also, I am in the USA, so if any of the sites in the UK dont ship overseas, or if its not worth it, please let me know.
Thanks,
Guy
Hi,
It is most desirable to use the best oils possible especially when working on high grade watches. I regret that this is one area where you should not skimp.
I agree that Moebius oils are very expensive though.
For the grease you can use Molycote DX which is really quite cheap.
If you are just practicing on scrap movements then you should be able to get away with Moly (grease), and 9010 and a heavier clock oil for the barrel arbor bearing.
If you are very careful you can use 9010 on the pallets in place of 9415.
But this is not a desirable solution on high grade movements as poor lubrication will cause poor watch performance and even stop a watch - I have seen it time and time again.
I hope this helps.
Hey DWDrummer,
I just noticed you are in KC. I am in Overland Park. What watch shop do you use? I am VERY new to the hobby myself. I have been collecting tools, reading blog posts, and reading Henry Fried's bible. I an currently going through the http://www.clockmaker.com.au/diy_seiko_7s26/ tutorial. I have taken a perfectly functioning Seiko and turned it into a pile of parts! I am waiting for L&R cleaning fluids to arrive so I can clean the parts and move forward.
At any rate didn't intend to hijack your thread just wanted to connect with a local amateur watchmaker. In the future maybe we could split costs on things?
Regards,
Alec
I hope this helps.
Is this acceptable for Molycote Dx??
http://www.amazon.com/gp/product/B00CAD6AAE/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A8FEBY5XL3B8V
Thanks,
Alec
Is Moebius 9501 acceptable for the mainspring? As I don't have 8200
Will I do damage to the mainspring by using 9501; or is it just due to the cost difference between the two that 8200 is the choice?
Hello, I'm a new member, I'm a lot into watches but with little experience. Still I think I can answer the last 2 posts. Please, feel free to disagree since this is all a learning experience.
To Alec:
I think the problem with the substitution might be a "spreading" effect potentially contaminating other parts in the mechanism. Oils designed for watches are supposed to stay in place. By using that molycote substitute you may be risking its interaction with other oils in the movement causing contamination resulting in decline of efficiency or worst. With that said, it would be interesting to consult the manufacturer and/or try it in a test watch and see what happens! It is my experience that a lot of products out there, sold as specialized items, come from widely available standards used in far related fields.
To Lawson:
Even though I have yet to experiment with other oils/greases including that one, I believe the Moebious 9501 is a synthetic grease used to alleviate friction problems. Normally we use "breaking" type grease in the main spring. This means that a certain friction is welcome inside the drum if I can put it that way for short. With that said, I don't think it will damage anything but make the mainspring slip and not work properly. This translates in a loss of power. In other words, your reserve may be less than optimal....
Happy watchmaking,
Robert
Dwdrummer, isn't Eurotool a brand Horotec endorses? I remember something I got from them made by eurotool...I think. In any case, I agree with watchrepairguy!
Happy watchmaking,
Robert
I think I finally cracked the Seiko oil equivalents according to their charts for 7S26/7S36:
Moebius A = Moebius 9010
S-4 = 8302
S-6 = KT22
Please, correct me if I'm wrong. Thanks,
Robert
Edited by bobm12
I know this link is getting old but I just found Seiko's S-4 and S-6 lubricants and they are not one bit similar to the ETA thought to be their counterparts/substitutes. Here are some pictures:
S-4 for barrel spring and some related parts (the black thing you find when you open those Seiko 5 barretls)
For keyless works and related: (anything requiring thicker oil than Moebius 9010)
Needless to say that Moebius 9010 is the lighter oil recommended Seiko call it Moebius A. It also uses it to lube the pallet fork jewels! (rather than Moebius 941!
In any case, if working on Seiko's these could be the only lube needed. If working with Swiss movements then oil needs will vary according to different brands even if they are based on ETA ebouchees. (Also the size of the ligne will influence the type of oil use)
Anyway, I hope this can help when choosing oils.
Robert
  • 4 weeks later...
Since Molykote DX can be substituted for 9501 for keyless work, can it also be substituted for 9501 on the cannon pinion and setting lever spring? The reason I ask is I'm trying to keep costs down and 9501 isn't cheap.
Thanks,
Don
I hope this helps.
Thanks,
Don
Keyless work includes the setting lever spring ;)
Moly should be fine with the cannon pinion although I have never used it for such I can see no reason why it would not be affective :)
I've seen this topic come up all the time in various forums, but somehow I'm still not clear on the greases. I'm starting from the charts for the Valjoux 7750, and will be doing various automatics, chronographs, divers/pilots.
9010        fine oil
9415        special oil for pallet stones
9104 (= HP1300)   thick oil (instead of D5)
9501      for driver cannon pinion, keyless works (instead of Molykote DX)
8217 (=Glissalube 20) for (automatic) barrel wall (instead of Kluber P125, which I can't get in small/cheap enough quantities).
Should I also get 8141 for the mainspring itself and the barrel floor ?
Is that OK?
I figure  that given the amount of oil we use in a watch -- we average hobbyists -- once we get some basic stock of the most useful oils -- sometimes making them do double duty in a pinch -- we are set for a big while. In the meantime, we can start stocking up on the other oils -- little by little -- so in the end we can service any watch with the proper lubricant. One thing to keep an eye on is the expiration date vs. how much we use them. It is a shame to have to throw out expired oil! So, as it goes, Moebius 9501 is next in my list! In the meantime, DX and others will have to double duty for it.
On a happy note for those on a very strict budget, Novostar type B can be used instead of Moebius 9010. I don't do this but I do have a bottle in my "traveling tool kit" instead of the more expensive 9010 which stays at home.
Edited by bobm12
OK, I ordered the following Moebius lubricants:
9010
9415
9104
9501
8217
8141
1 ml of each, except the last two, which were 5 ml. Total, just under 100 €.
I've got a silicone grease in the O-ring sponge cleaner/applicator.
Re HP 500: I was looking to get fewer oils/greases, not more :-)
By the way, a tip from photography film development: you can increase the shelf-life of chemicals (oils) which are prone to oxidation by adding small glass beads which displace the air from the container.
Oh, that takes me back! The marbles were made redundant when polythene bottles came out because you could squeeze them.
This topic is now closed to further replies.
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
