Rolex 3055 Hour Wheel Seating
GeorgeC
Thank you but this is for the rolex 3055 that has separate day and date indicator discs.  I believe that the round flat washer I am speaking of goes on top of the day of week disc then the dial on top of that.
I have put the watch back together but when the day/date changes at midnight, I don't get the full kick over to the new day/date like the watch should.  Just second guessing myself on the hour wheel seat and whether I forgot exactly where it should be placed.   If there are other suggestions on where I can look on the date change issue, please comment.
Thanks
Thanks for the link to the tech manual.  I really couldn't read where the hour wheel seating was to be placed from the all of the text instructions.
There are 4 variations of thickness, thus 4 different part numbers listed 5123-1 5123-2 and -3 -4.  As shown in the picture, flat and thin.
10 minutes ago, khunter said:
In the disassembly section the wheel comes off then the seating. On page 16 the seating goes on, then the wheel after lubrication. In your first post you said hour wheel, not date, which is why I thought you were talking about the dial washer.
Ok disregard all of this......i read and re read and finally figured out what seatings they are talking about. You are correct, they don't say where the HOUR wheel seating goes, but from what I can tell it must go between the wheel and dial, to have the correct endshake which they do specify as .03mm. Im not sure if that is causing your date jump issue though as they describe increasing and decreasing tension on the jumper spring to correct it.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
