Pinning the hairspring to the stud
fuse63
Real quick question on repinning the hairspring to the stud. Should you remove the hairspring from the balance wheel in order to do this and to make it level or is it best to just leave it on the balance wheel? Any other tips and tricks to make this easy and smooth would be great. Thanks
Absolutely you will have to secure the new stud. There is a dedicated stud holding tool (bergeon) but I use this tool also manufactured by Bergeon.
5a8d9600a23e9_ScreenShot2018-02-21at15_51_51.png.77aed5b64a40284ad35eadf40f57b3e7.png
If you are fitting the end stud then you can use the balance arm to secure the new stud. If using this method after fitting the stud remove the balance assembly & turn upside down and then fit the spring and pin. However be careful when pinning as one slip & you can very easily damage the hairspring.
Quick answer is Yes, it would be better to remove it from the balance, you could easily slip and damage the wheel, and the hairspring needs to be laying as flat as possible to remain stable. Overcoils are a different matter, they're going to shake around no matter what the main coils are resting on...
Normally the stud will be secured in a fixture, upside down, where you can get to the hole for the spring and pin. The spring is inserted (upside down of course), and then pinned in place, which is the most fiddly part.
I need to do this task and it seems to be very difficult as you need three hands. Do you need to prep the end of the hairspring to easily fit into the stud
Na just a good pair of tweezers and a steady hand.
1 hour ago, jdrichard said:
Once the spring is in the hole, i need to peg it in. Soooo smalll:)
if you're using the original pin then yes, it is virtually microscopic. Using a new hairspring pin and then trimming afterwards is the best route
Robbed a pin off a russian movement as the original got lost(my issue, stuck to my arm perhaps). Need to hold the stud with a pin vice or another vice and place the spring in place and then try to slide in the brass peg and secure it. Ahhhhh. Need a tool:)
I've often thought of making a hairspring stud table, like Bergeon made. Simply two pieces of flat steel or brass stock, about 1/4" thick, the first piece about 1.5x1.5 inches square, the other 1.5x.25 inches. Line the two pieces up along the long edge, drill and tap for a screw at one end about 1/4" from the end. File a couple V notches of different depths near the opposite end on the narrow piece. where the notches are perpendicular to the flat face. Screw the two pieces together lightly, insert your stud with the hole accessible in one of the V notches, and tighten the screw to hold it in place. Bergeon used a lever to pry the two parts apart, but this method would work to, just not quite as convenient.
Yep basically the same I described
Another tool project. Will also put little legs on it and make it from a 1/2 inch chunk of steel for stability. Then i will re-stud the darn hairspring and reinstall in on the hampden staff i made and them see if the whole thing now ticks:)
Need to draw a picture of this.
I'll try to whip something up here in a bit
I may make it more similar to theirs, as 2 screws on the one end would keep the two plates aligned horizontially. Even the little lever wouldn't be that hard, cutting the slot for it would be the challenge.
2 minutes ago, khunter said:
Bergeon (and the people that own them) are VERY proud of their tools, and prices reflect it unfortunately
Question is, is that a founded proudness, or some sort of snobist show-off?
Because, you know, Bergeon doesn't even make tools, they just resell. Leveraging a century-old high-profitability business model which is based on perceived exclusiveness.
True "value" is almost always perception. It's worth what someone will pay, and in their case, people pay the premium for the name, and I'll admit, the quality is there as well, but is it truly "worth" the asking price? I guess the market decides.....
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
