Sizing loose hands
Folkvisor
I am having a problem with the hour hand on a watch; the friction fit isn't tight enough to hold it in place.
Would it be OK to very carefully squeeze it together a little? I'm a little reticent to do this.
Would a small amount of Locktite - the non permanent kind - work better?
The procedure is in the book 'The staking set and how to use it' i believe there's a free .pdf somewhere if you need it, it has been posted on the forum before.
Only thing is the hour hand coming loose might be a direct result of the loose dial.
Edited by Ishima
I have in the past used a small pin vice as these hold the tube in four places, gently tighten up and test and adjust as you go until the hand fits, the other way I was told was to gently using a screwdriver blade push the hand tube over just a smidgen,  not scientific but both ways have helped me in the past, the pin vice is the better one though.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
