Etanche 73 movement
rogart63
That is great . Have a lot of Cup 233 parts . But wonder if i have a mainspring ?  But that would be no trouble. Thanks well spotted. Can see the marking is the same as my movement to.
Edited by rogart63
3 hours ago, wls1971 said:
Cupillard 233 I think check Cupillard on the ranfft site.
Do you think i can order a mainspring without checking the size on the original. Maybe better to remove the spring tomorrow and check if  the sizes are near the ranfft listing.
One of the few movements that can be identified from the bridges due to the distinct barrel bridge, an incredibly long production run in various versions from 1935 to the mid 70's, shock resistance introduced to the movement in the 1940's. I dont know in that time how the movement developed and if different versions have different mainsprings but the movement you have is a early one so I should imagine the mainspring will be the same as listed on Ranfft but you are going to have to take it apart to fit it so you may as well check.If you remove the dial it will probably have the calibre number stamped on the plate.
Cousins list the GR4870 1.70x.095x9x320 which differs only slightly in length when compared to Ranfft
9 minutes ago, Deggsie said:
I love it. Reminds me of the ‘dirty dozen’ design
This has military background to. But can't say how . Not into military watches. If i understand right Etanche means waterproof in french?
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
