French mantle clock by Vincenti Cie
Conduit
Hello gentlemen,
I would like to get fixed my antique  French mantle clock manufactured by Vincenti Cie but the local clock service quoted me £300 for replacement of pendulum & French suspension spring.
I found a website which offers clock parts for French movements for reasonable prices and would like to purchase the correct pendulum and a suspension spring to reduce the cost of repairs.
https://www.cousinsuk.com/category/pendulum-clock-suspension-springs
https://www.cousinsuk.com/product/french-clock-pendulums?code=P1132
Would someone be kind to point out which of the parts will suit this movement? Frankly speaking, I am in doubt that a suspension spring is actually required, it seems to me that only pendulum is missing but I am not a specialist. Any advice is highly appreciated.
The clock certainly does require a suspension spring the one in your picture is clearly twisted and broken, you also need a pendulum of the correct length, french clock movements usually have a serial number and a number that indicates the correct pendulum length the number is in old french units called pouce and lignes these can be converted into millimeters to give you the length you need.
If the price of £300.00 includes servicing the clock that to me would seem very reasonable, it is a time consuming and surprisingly messy job cleaning a clock.
Wis1971 is correct. The only thing is with your clock it does not appear all the numbers are there. To properly clean oil and replace parts with these movements is very time consuming. Every brass part should be polished; every screw should be polished and blued. You do not just wash the movement out in an ultrasonic tank. If the place you took it to do that sort of thing then take it to a proper clockmaker.  £300 is too much; around £200 including parts would be I think a fair price.
 Here is a photo of the fitting of your clock for a new suspension spring, I think this one should be right for your clock, you might need to file the top block a little in order for it to fit, both blocks must close tight when screwed back together. Also I have picked out a pendulum that should be right for your clock, again you will I expect need to alter it a little.
Ø35mm (No.1) Pendulum & Hook*
Suspension spring  S5558
Edited by oldhippy
Wow that is a beautiful clock c18 60/70?? Well worth restoring..looks like you need an 8.4 pendulum (90g??). I did have a table somewhere, if I find it I will add..There is someone on Ebay that cleans clocks for about £95 full strip and clean..I don't know him or his work so can't vouch for him..Also pendulums come up now and then along with suspensions...I would love to clean that one, especially with the outside count wheel nice easy one...alas but my eyes are not all that good a present..
Nice keep good luck with that one..
Thank you very much, gentlemen, for your  input and assistance. The figures above the maker mark state 6-4 which I converted into 171.44 mm of the required pendulum length. I will buy the pendulum and  a suspension spring as advised and carry on searching for the local clock maker to service the movement.
Sorry.... did not see the figures above the makers mark..I did say I had bad eyes...lol... and usually the pendulum marks are at the bottom of these movements.. by the metal securing plate pins..
Len
    • All Done, Here are the finished pictures: This one shows the generic "one-size-fits-all" base which accepts the bespoke rings - notice that the parametric movement OD (27.40 mm) automatically prints on the ring 🙂 From another angle: Here is the ring about to go into the base: And finally the base and ring together: Here it is next to a pen for scale: On my system with 20% fill each ring will take about 18 mins to print, but I am sure this could be optimised: Here is the screenshot of the spreadsheet in FreeCAD, you just need to change one value to create the ring in cell C3, (the base doesn't need any changes). I'll upload the files to printables in due course, but here whey are as a fake pdf, please change the .pdf to .zip to make the file work once downloaded: Modular Movement Holder.pdf Any feedback welcome!     I'm also going to make a parametric ring insert for rectangular/oval movements - but I just finished a parent teacher evening so too tired now 🙂
    • I'm going to give that a go next time, thanks for a great idea @rossjackson01 One of my students uses this tool and swears by it https://www.cousinsuk.com/product/wheel-hand-roller-remover-bergeon?code=W1851 which is very like getting two sticks of pegwood under the wheel and rolling them in your fingers so they create a slight prying from underneath motion, I suppose. Maybe bind one end of the two sticks of pegwood so they are like tweezers.
    • Thank you. I spent a lot of time on that.   It never ceases to amaze me that there are so many slight adjustments that can be made to the chronograph mechanism through setting the eccentric studs to get them all to a concerto, like an orchestra with everything in time and to its most optimum. Understanding that setting one stud to the desired effect may throw another out is the fun of working on vintage chronographs. Great pic of the 3133 dart tooth interaction and tilt of the tooth. I love working on 3133s. Slightly better than the 7733 in my opinion and you get a date at 6!
    • Thanks Richard The stem is 0.6mm wide. At least the part that the crown goes onto. Is that enough info to order a new stem and crown and look a pics of the stem so check that the part that goes into the keyless works matches the one I have? Asking out of ignorance! Cheers, Nick
    • Probably Chinese, you can measure the stem you have.
