Vintage Tag Heuer Formula 1
mdhc500
Hello, I would like to request some direction. I have a vintage Tag Heuer Formula 1 that I am need to replace the movement on. I have the stem out, movement out, hands off, but I need a nudge in the right direction on how to remove the dial? I think it is a Harley Ronda Movement HQ705, its marked with Tag Heuer 3.88 . Can anyone help?
Thanks!
It's definitely a press fit. Sometimes I've encountered a bit of glue between the plastic spacer thing and the dial itself.
I usually just try to find a space where I can slowly and safely insert the screw driver tip and slowly pry it out. I do this in multiple spots along the movement/dial until it comes out evenly so as not to break the dial feet.
