Help with new tailstock
dwhite
turret.jpg.4cb40062f4cf21a590a4bcfddca6102c.jpg   I just bought another Perton lathe and it came with two tailstocks.  A regular one that isn't broken (yay!  I finally got a lathe with a functioning tailstock) and this one in the picture.  I took several pictures but Apple is conspiring against me and won't let them upload so I'll start easy.  I think this is a turret tail stock from looking at pictures online. One end has a taper that looks like it would accept a collet although an 8mm collet sinks so far in that it is flush.  Could it be for a 10mm collet?  Or something else entirely?  I tried a morse taper 2 drill chuck from my wood lathe and it doesn't work on either end.  How in the world do you attach things to it?  If I can get my photos to come through I'll post more.  Also, it doesn't lock down because the button is all bent up.  I hope someone can enlighten me.  Thanks!
OK, I got my iphone to work.  Here is a picture of the bottom of the tailstock showing the button is badly deformed.  It doesn't lock down.  Can I put it in a vise and tap the steel back into position?  Should I heat it with a torch first?  It sort of looks like a crack might be forming where the round button connects to the shaft.  Help!button.thumb.jpg.d625cc31c04d5e9ef8bfd88a9a4d208a.jpg
More.  Here is a picture of the front bore showing what looks like a taper for a collet.  The second picture shows a standard 8mm collet in it.  It sits way too deep and would probably go even deeper if you could rig a way to tighten it up.  There isn't a pin to fit the keyway of a collet.
frontbore.jpg.2ee66e86d713b46bc1b5e90b450a4e68.jpgfrontcollet.jpg.211cff22db89075a6dc657aee7f24e20.jpg
L ast one.  Here is a picture of the rear bore.  It has a short chamfer and, down deeper and hard to see, a ridge where the diameter decreases by a fraction of a mm.  I don't know how one goes about measuring something that deep.  Here an 8mm collet sits about right but there isn't enough material to support it.  I tried a MT2 chuck in both ends and it didn't fit as you might expect since neither taper is long enough and the taper appears wrong.  So that's my best description of this piece.  Anybody know what it is and how to use it?backbore.jpg.87f705070cbc09039d26519ba13747e2.jpgbackside.jpg.88444900ae6fe336430e8a429f2b7995.jpg
There may only be two of those on the planet and you found them both, nice!
Its not a turret tailstock - example of a turret tailstock below.
I do think watchmakers lathes that take collets in the tailstock are somewhat rare, at least they sell for a premium.  I've a Pultra that does, buts a bit bigger, 10mm.  No idea why its seating the collet so deeply.  what are the drawbar thread particulars - dia and pitch?
A Morse taper is a self holding taper - unlike watch collets that are steep and self releasing.  The taper per foot is much less (around 5/8" irrc).  MT 2 or even 1 will look huge compared to a watchmakers lathe....there is a MT 0 but I can't see from those photos where it would go.
As for measuring the bore, there are lots of tools but the most basic is a set of small hole gauges and telescoping gauges.  These are set then measured with a micrometer.  Cost and accuracy goes up from there.  A set of small hole gauges irrc usually covers from 1/8 to 1/2"
As for the bent piece, some ham fist maybe got a little over zealous.   You could start banging around on it, but you could also wreck the fit of the rest of it easily enough.  I'd make new one out of something tough - a preheated chrome moly like 4140.   As its not holding, I'd say make one or draw it up and get it made.
Edited by measuretwice
Thanks!  I called it a turret because it was the only thing with a lever that matched what I have.  Do you suppose it had a draw bar at one time?  I'm wondering if that's how it worked.  I have some casting equipment that I'm not sure still works but if it does, I could cast an insert for the back to accept a drawbar out of brass.  As far as the button, that's way above my ability to make and I don't have any way of holding stock that big.  I don't know for sure but I'm guessing a machinist would charge a young fortune to make something like that so I'll probably be going the hammer route.  I'm guessing that getting it red hot would make shaping it easier but I really know nothing about steel.  The thing, whatever it is, is really a precise machine and functions very smoothly.  It would be a shame to let it go to waste.  Think of the watches I could ruin with it!
lol, before you take a hammer to it, carefully measure it and draw it....if hammering does scrap it, you'll have what you need to get some quotes.   I don't know what is not shown on the rest of it, presumably just a cross drilled hole for a cam?  imo its well less than an hour's work so might not be too bad to have made.
The problem with getting it red hot, is the metal has the consistency of Plasticine.  you can easily bend a 1" bar by hand for example.  So, a hammer strike might bend it downward, but it will also spread out under the hammer, as if you were hitting Plasticine.   If you can, with a small oxy acetylene torch, get a red zone as strip along the bend line, that would be ideal and bending it back easy, otherwise you may better cold forming....but be really careful not to bend the vertical column.
Also, on heating it, if its cross drilled for a cam, it may be that that part of it at least would have been heat treated (although the mushroomed bottom suggests its something less than tool steel strong).  Get the whole thing red hot and you undo the heat treating.
I would guess it was made to accept collets so would have a drawbar...no knowledge of that lathe, just probable speculation based on a tailstock quill that appears to have a self releasing tape (as in collet style) vs a Morse taper.
Thanks!  I'll try the cold approach.  If it cracks I have a neighbor that is an expert at welding small cracks in steel and he would happily do it free.  Now I have to come up with an idea for a drawbar.  I'm not very mechanically minded yet (which is why I'm having so much trouble with watches).  Since the 8mm collet didn't fit I suppose it was made for a larger size?  I've never seen a 10mm collet, do you happen to know if they are that much bigger in the face and tapered part?
4 hours ago, measuretwice said:
I just measure a 10mm PTA, it was 15.1mm dia, large end of the cone.  Body of course is 10mm.
I'm doing some research and wondering if you know if the standard 10mm watchmakers collet is the same as the type D collet?  I see both names tossed about, sometimes in the same discussion.  Also, I found an ebay listing for a 10mm lathe with a Levin micro drilling tailpiece that functionally does the same thing as mine so that must be what it is for.  Levin makes a modern version which sells for $1800!
My impression is "D" collets are 10mm collets, but don't go buying a set on the strength of that.  There is some info here http://www.lathes.co.uk/derbyshire/.  i'm sure I have at least one Levin 10mm collet, let me compare it to the PTA collets.
You could probably find a drawing of a Levin collet and see if it will fit.
With all these collets, there is no "standard" unfortunately.  Their origins date to a time when everybody did their own thing.   Now a large number are interchangeable, but not all ....there can be slight differences in the thread and length overall and even the body dia.    If you hunt about on the web are two lists of collet dimensions I remember seeing, one for European lathes and one for US lathes.  They might give some clues
Finally found the proper name for this tailpiece.  It is a Levin 10mm collet holding tailpiece.  I got a drawbar that seems to fit exactly although I don't have a 10mm collet yet to test it.  I have one on order.  From dimensions I have found online for 10mm Levin D collets it should be long enough to engage the threads.  If not, I'll have to find a machinist to turn a bit off a shoulder on the drawbar.  Thanks everyone!
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
