Timex 'watercolors'
Len33
Does anyone know how to get the movement out of this watch?
When viewed under a stereo microscope, there is no joint to be found around the front
or anywhere else.
(Only the bezel is removable)
From the inside, it is plain to see that the dial is under the edge of a section of moulded
plastic edge; so it has to come out through the front.
What on earth is holding this watch movement in place!
I tried a watch crystal lift to see if that was the way forward.
However, the crystal refused to move and, to avoid damaging the edge of the crystal
I dumped that idea.
Is it really cemented together and never intended to be taken apart, or what!
Over to you, for any ideas and suggestions.
These watches where produced by Timex as direct competition to the Swatch watch in 1984 when the craze for cheap colourful throw away watches began to take off and like Swatch I dont think they where ever intended to be serviced, if they didnt work when changing a battery you just put them in the bin and bought a new one.
Like the Swatch I think the case is probably moulded around the glass crystal making it cheap to produce but impossible to remove without ruining the watch.
Thanks for you response, wIs1971, it more or less sums up what I was thinking.
A shame, really, because I was so much looking forward to stripping the case down; getting my rubber gloves on and giving it a good scrub in the sink.
Oh well, it'll have to be a quick 'cat's lick' for this and move on to the next one from my lucky dip bag of salvaged time-pieces.
Regards.
Len.
I know. That's why I didn't mention the crystal lift as that would only work on acrylic and this one is glass or mineral glass, I'm assuming...
I'm thinking that they inserted the movement and dial and then just pressed in the glass without thinking that someone would ever be in a situation like yours... Then again, it's a cheap watch so I guess they didn't care.
I have another solution that would work.
You can use some glue such as Hypo GS (the transparent one, for watches and jewelry) and glue something to it, and then just pull out the glass. You know, the same method some use for stubborn case backs.
The cement itself washes off with lacquer or even isopropyl if I'm not mistaken.
Edited by Chopin
    • Thanks all.   Movement is a Helvetia 800C. Don't know any history e.g. if the broken mainspring is original. Watch was bought recently as non-working. Really interesting piece that Jon, thanks. I'd only been thinking of length relating to power reserve. I don't have a mainspring winder (yet) so I'd like to avoid winding the spring into the barrel by hand. The old spring measures at 1.60 x .11 x ~290. Sorry, can't be exact on the length. The piece I still have is 275, but the second piece escaped during measurement. Best measurement I had for it was ~13. The micrometer does zero accurately so I'm pretty confident of the .11 Also, I'm getting the barrel ID at 9.5 on a vernier. I'm now wondering about going with a .11 spring? Given all of the above, maybe 1.60 x .11 x 300 x 9? Any thoughts? Cheers.
    • Funny that you should bring this up. I was thinking about it just the other day. What happens if something happens to @Mark? The social bit is fantastic and I would miss it dearly, but I worry even more about the content. Together we have created a gold mine of information which would be more or less irreplaceable if the site should disappear. People (often with a lot of knowledge) come and go. I sometimes wonder what happened to them and miss them. We have no idea unless we have some private contact information. When I was new here I saw a lot of posts by @Lawson. He had a true fire in his heart for horology and was asking for an apprenticeship in his signature. I found that very inspiring and often wondered what happened. Is the fire still burning? Did he get an apprenticeship?
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
    • What I especially like is that this forum is not full of ads. There are some but they're not interfering. No ads between posts like one certain big watch forum. Browsing is also very easy and light for a mobile device. I'm glad there's still room for old school forums like this. I'm a member in many facebook groups but there's really no long term discussion and if you see an interesting post you might never find it again if needed.
