  • Similar Content
    • By PaulnKC
      Greetings all.
      I recently acquired a moderately old Benrus 3-Star Automatic wristwatch. It's a #7026 Series.
      I believe these are from the 60's - though I don't know much about them.
      On the back of the case it says "open through crystal". Which makes me think that the Crystal should be removed using a Crystal Lift - and the movement lifted out through the bezel.
      Of course, the stem (presumably two-piece) would have to be separated prior to - or during the operation.
      BUT - after some googling - I have also heard tell - that the case-back should be pushed out by pressing on the crystal with thumbs. These seem to be incompatible methods - but I really have no idea - as I have never seen a case like this.
      Does anyone have experience with this type of case from Benrus? I can post pictures after I get home - if they are needed.
      Many thanks!
      -Paul
    • By GaT34
      Hello All,
      I am new to this forum and relatively new to repairing watches (so please don't bite!).
      I have repaired a couple of cheap watches before and both have worked out fine so decided to try my hand on Benrus I have had for a couple of year and am quite fond of.
      All was going well and then I had a pet related incident whilst opening up the mainspring barrel. By the time I had found the barrel (cap, arbour and mainspring conveniently ended up in my lap) it had been damaged and some of the teeth destroyed.
      I have tried to identify the movement in order to figure out what part to try and find (picture attached, apologies for the poor quality) but really struggling as it doesn't look like any other Benrus movement I have seen anywhere online.
      The watch has 1974 on the back (looks like a "length of service" gift awarded to someone by the inscription).
      I bought it from ebay and the seller doesn't know anything more about it. If more picture of any more of the parts would be useful please let me know.
      I'm just hoping that someone will be able to help.
      Thank you in advance.
      G
    • Reduce the distance between the two Disks that center arbour are mounted on.   Use a staking punch or a metal tube with ID larger than center arbour OD. tap on disks to push em closer together, thereby taking the slack out.  Use of a thin washer like you say works too.
    • Hello, I am new to this website, but a watch lover. I have a mechanical watch which is pretty old, and it's crown broke from inside when i was trying to wind it up. The crown has come apart with the stem, and the gears linked to this stem are still inside the watch. Does anyone have any advice as to what I should do? Get a new crown or is there any way to fix this already broken one?
    • Yeah pretty much this is related to the bearing. You could ask any watchmaker who services automatics and he should pretty much have one.
    • The reason it rubs is because there is wear in the bearing. Proper repair is to replace the bearing. Sorry no leads on where to source a bearing. I think I did cannibalize one from an Orient but that was a few years ago. Good luck Anilv p.s. Even if you do file down the heads of the screw My guess is that the rotor will then hit the edge of the automatic device bridge.
