Parts for my Gramps' Pocket Ben
So my Nana gave me my Gramps' Pocket Ben he's had as a work watch, but the chain loop on the top is missing. I took it to my local watch repair and they said that you can't replace that loop (I think it's called a bow?) on any watch because "it won't have enough tension".
Is this true? Because I'm pretty sure I've seen replacement ones on eBay and Amazon, but I don't want to order any if I can't actually put it on.
The bow is replaceable, and I believe I just saw some pocket ben bows for sale actually. You need bow opening and closing pliers to do it right, but it can be done with care with standard needle nose pliers. Generally, squeeze the bow a little tighter than it needs to be when fitted, then use the needle nose to spread it just far enough to fit into the stem holes, then release. It should spring back slightly and hold snugly in the stem. Sounds like your jeweler just didn't want the hassle, or your business.
I haven't seen a Pocket Ben in person but...
On the 1800's and early 1900's pocket watches with plain circular or oval shaped bows (Pocket Ben styles 1 - 2a), one uses bow pliers to bend and adjust tension on the bow.
I am assuming the material used in the Pocket Ben is similar to that used in the various cases I have and
They have little nubs on the end that fit into a sort of socket on the stem tube and are held in by tension.
If it is style 3 and up, then I defer to others. I would think a parts watch would be the way to go if there is a way to replace that newer style bow.
Old style bow assortments come up for auction often. I have some larger spares if you need.
Ref: https://clockhistory.com/0/westclox/series/series-17-1.html
Sent from my Pixel 2 XL using Tapatalk
Thank you for your replies, everyone! I went and got a second opinion at a watch repair in another city, since this guy was the only one here, and they said no problem, turns out a friend of his out west has a few bows for my watch, which he is going to ship to my address, and I just have to cover the shipping cost. It's a style 6 pocket Ben from the '60s.
Right now it's got an old jump loop and cheap chain that Gramps rigged on after the bow came off. But I'd rather get the actual bow that fits it, because I'm worried the bent-into-shape jump loop's going to let go.
  • Similar Content
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
