How do you source a new balance staff
You have to first identify the calibre number of the movement in this case im pretty sure its a Lecoultre cal.201 then search for a balance staff for that movement, all the usual places like part suppliers or ebay.
Obsolete clock and watch has them at 25.00 a piece these movement went into aircraft clocks so parts will be scarce and costly
I recently needed a staff for a military pocket watch calibre 467 £20.00 each I then needed one for a calibre 415 a much rarer movement £8.95 for 12.
So first off you need to establish the calibre.
Thankyou, I quite often get old watches with no makers name or cal numbers so how do u go about searching for a Calibre number if u don’t even know who has made it.
This subject has been discussed at length in various posts on this site if you have the ligne size you can obtain reference books such as Bestfit, Paulsons, flume, Catalogue official and match the setting parts of the watch to diagrams supplied in these books that will allow you to find the maker and calibre because lucky for us these parts are unique to each maker and allow identification, if you dont want to buy these reference books then you can always ask on this site but you would need a picture of the front and back of the movement in order for someone to help.
Search "ranfft database". Has many, but certainly not all.
BTW, that JLC is beautiful, wish you the best in getting it to run again.
ok thankyou i have the bestfit books i will give it a go
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
