Hi all
earlyb
Hi Guys.
Im new to this. Found your forum via googling a question.
Ive had a read and found this place to be a great friendly community.
35 years ago my cousin lent me a family heirloom, a pair of pocket watches on a double Albert chain to wear on the day of my weddng. They'd been passed down to him from my late grandad.
I have never forgotten those watches and the sentimental ties to my past.
They weren't working at the time (not sure if they've since been fixed) but recently Ive been thinking what a gift it would be to have the knowhow to be able to repair old watches like the pair I wore all those years ago.
Im looking forward to giving it a go. Ive bought a couple of old non runner cheapie watches to start on and a few tools which ive seen suggested on here and youtube.
I have a question but I'll ask it in the appropriate forum.
Thanks for reading.
Dan
Sent from my GT-I9195I using Tapatalk
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
