How to remove dial screw
GeorgeC
I have a Bulova 10BT with one of the dial screws slightly rusted and the head of the screw is stripped so that a screwdriver will not engage to back out the screw. What can I do to get this guy out?  Small twist drill bit and drill out?
If you drill out, you'll ruin the thread. The normal procedure would be to soak it in alum for a few days and the screw would dissolve, however, if the dials still present I'd very much hesitate to do that, any chance of a picture?
  • Similar Content
