Hamilton Chronograph movement removal
bigboy
Hi,
I just bought Hamilton Jazzmaster Maestro Chronograph Н327660. I'm in love with the watch, but the case is very worn and scratched. and decided to polish the case, so have to strip it down.
I have removed the back, removed the crown, removed the two screws holding the movement to the case.
Then turned the watch, but the movement didn't  came out. Any idea how to remove the movement from the case?
Thanks in advance :)
It is likely a front loader, you can search for these terms here or on google.
However considering that is a valuable piece I recommend that you do not attempt to work on it without the necessary knowledge and tools; give it to a professional.
Thanks for your reply and advice jdm. I'm watch enthusiast and have moderate knowledge and more than basic tools :)  I have done lot of research on google, but nothing came for Hamilton H21. Im also considering it as front loader as have found a hole on the case :
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
