Gruen Geneve. 23 Precision Powerdate
Eckehardt
I just bought this watch for $2.00 a few days ago from an antique shop. Seen better days. Just slightly serviced the movement. ( no binding of the autowind) This has the 23 jewel 560 RSS an upgrade from the Bidlingmair ( however one spells)  ebauche 17 jewel but with autowind. Now as for the year. Could this be a pre 1976 or 70s watch before they went defunct?. I know this company has been pretty turbid since the late 50s. The numbers on the inside are as follows upper 269135. Bottom 251. I think this is a Francois Borgel case with the F.B. and key under the FB. Also underneath are the words Vaccum. The watch has been running for 2 days now. Any idea the year era? Nothing on line seems to match.
Hi Eckehardt,
Thats a nice watch and well worth servicing.
I posted a Favre-Leuba the other day and wls1971 shared some info on the 'vacuum' brand. My guess is that it is from the late 60s.
On 1/13/2018 at 9:53 PM, wls1971 said:
That's a very nice quality watch the case is made by Taubert and stamped with the Francios Borgel trade mark which they owned the watch is as you say mid 50's which is when Taubert started using the word "Vacuum" as a trade mark. Most of the Taubert cases of this period where stamped with serial numbers between the lugs so I'm not sure if they are from the case maker or watch manufacturer but I have West end watches and Movado watches with these cases that are stamped in a similar way.
The strap I believe is a Vollmer which are a German watch bracelet manufacturer founded in 1922 and know for quality mesh watch bracelets they used the trademark Aristo
Pics of the watch here.
rgds
Anilv
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
