2836-2 Casing
Hi
I am having a problem casing my 2836-2 movement. The case has a spacer because of the size difference. That part seems OK.
The main problem is the second hand pushed against the crystal when the caseback is tightened.
There are case screws and a ring to put on the movement but, I put it on, it doesn't fit in the spacer ring properly. It's also very hard to fit.
Any suggestions are welcome.
Dave
Are you assembling your own watch from spare part from here and there?
Then the onus is on you to resolve any impinging part and other issue, it may require fabrication and imagination. No ready recipe, sorry.
  • 2 months later...
I was having problems with a casing kit for the 2836-2.
First, it wasn't made clear that placement of part 145, the ring that fits between the dial and movement, was absolutely necessary; it allows the day and date rings to turn freely.
Second, there was a spacer ring to go between the case and the movement supplied with it that didn't fit properly. I used some pieces of small rubber tubing as a spacer instead. I'm thinking that this fix isn't exactly good watchmaking technique but the watch works now and it didn't before, so...
Just thought I'd pass that along for anyone who is looking to case a 2836-2.
This was used by IWC in the sixties as a way of protecting movements from sudden shock I have a Yacht Club that uses 5 rubber blocks as spacers, it was also used by other watch makers so the idea must have some merit.
  • jdm locked and unlocked this topic
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
