lathe file rest
dwhite
Does anyone know how to make a lathe file rest or where to get one super cheap?  I was thinking of cutting down a graver sharpener jig, the kind with the roller, and affixing aluminum bar stock of the correct diameter to make one.  I picked aluminum because the jig is aluminum.  What do you think?  I have two lathes and the tool rest holders take 6mm on one and 7mm on the other and haven't been able to find a rest with the correct post diameter.  Thanks in advance!  Dan.
If you don’t have a lathe, why do you want a file rest? You should go to a machinist shop and buy one readymade. Here is a photo of a simple rest it might give you a pit of help on what you can design using simple tools. If you want to practise filing, correctly get hold of some scrap metal and a bench vice and file and practise on that. There is a right way and many wrong ways when it comes to filing flat.
This one looks decent:
http://www.model-engineer.co.uk/forums/postings.asp?th=78631
That just requires rod, a section of gauge plate, screws, delrin, and a tap and die set.
You could make the retaining rod the same diameter as our tail stock (eg. 8mm) to fit in there, and then replace the delrin tubes according to what height you want to work to.
oldhippie and rodabod, both of those designs look great.  I'll have to search for some suitable rollers, not sure where you could find something like that but I haven't started looking yet.  I could easily build that out of brass and silver solder it together.  A jewelers saw ought to cut the frame.  Thanks jdm for the reminder that I have two lathes.
They're both 10mm as you know.  The threads are the same pitch/form/OD, but not the same length along the body (pultra is longer).  Pultra (mostly) does fit Levin.  Levin doesn't fit Pultra - the longer thread section I suspect would be an issue but the slot for the pin is wider on the Pultra collet so the Levin collect couldn't inserted.  The Pultra collet is slight proud of the spindle nose when installed in the Levin - the large diameter is a little more than the Levin (meaning it fits but sticks out slightly, why I said mostly).  The tapers visually look the same but before buying I'd try and find some documentation confirming the angle.   Hope that helps
Edited by measuretwice
I think the Pultra collets were made by Conflex. As far as the 8mm ones are concerned, I found they are compatible with Wolf Jahn, Lorch and what I generally refer to as WW collets (although I guess that American collets probably vary amongst brands).
  • 6 months later...
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
