Installing mainsprings
Eckehardt
A mainspring winder is necessary when it comes to clock springs. Winding in by hand can distort the spring. This can cause the clock to be poor in timekeeping, cause unnecessary rubbing/wear to the inside of the barrel and barrel top. With the rubbing, it can weaken the spring. The same can be said about watch springs. New watch springs come wound, you can just press them in with no distortion.
There are many different types of spring winders if you are going to invest buy a good one, with watch type ones, find out if they will undertake the task of all size springs and fittings. The same goes for a clock winder.
Agree mainspring winders are the way to go. I’m attempting to build up a complete secondhand set from ebay purchases due to the cost of new sets. I’m about 2/3 of the way there with an old Bergeon 30081 set but still searching for sizes 9 to 15. Cousins sells some new ones singularly (not all) at around £45 each. Would you know any other sources one may acquire them?
Have you tried ebay? I see you are in England try auctions or even second had shops that sell tools. How about old watchmakes near you. When I lived in Lyme Regis I woul go to Bridport on market day as a stall sold second hand tools.
Thanks for the tips. I shall keep a lookout.
I have to track my spring winder down . It is in a shelved tool cabinet at my moms. I was really carefull when putting this spring in. So as to not kink it or bend it or to scratch the barrel edges I know it's a pain or even unsafe to do it that way. The spring winder I have is an adjustible one for different barrel sizes. It's an old winder.
Edited by Eckehardt
On 14/01/2018 at 12:30 PM, Pip said:
Well I could have done with one today, I went from this:
To this:
Ok, it’s a 40 year old ms but I’m not sure that it wasn’t at least partly me.
The type with the bridle on the end are a bit tougher. Yes and when they're older they can break. Depends on how they were treated. For those and any others use a spring winder. Last resort method. On real high end watches a winder is a must.
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
    • glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed 👍
