A simple screw...
Pip
I’m sure this is a very easy one but I’m damned if I can find the answer so thought here would be the best place. There’s no such thing as a stupid question and all that...!
Anyway, been working through a junk old pocket watch. Got it done now (I think) BUT of course the dial is broken and one dial screw is missing too.
My questions are: What screws do I need to order from Cousins? Are they a standard size thread? And do I get bigger head screws or tiny washers? Or just order a new dial? You’ll see what I mean from the pics.
Shot of dial and close up of one side of damage:
Pic of screw on Dumont No2 tweezers and close up:
Thanks for your help!
Pip
Hi Pip, dials usually have feet or posts which go into holes in the movement. These feet are then secured, usually by a sidescrew.
In you watch I believe the feet broke off and someone in the past has used a screw to secure the dial. If you can get the feet replaced the damaged can be visually repaired by some epoxy and white paint. Not perfect but not immediately noticeable as there is very minimal damage to the minute track.
Anilv
Thanks. Is that always the way as my case seems to be built with threaded holes just where the screws go. I’ve packed up for tonight so will check tomorrow but they don’t seem like add ons iirc. But you’re right in that every dial I’ve dealt with so far (all wristwatches admittedly) has dial feet of some kind.
Dials screwed to the movement  from the front are uncommon but not unheard of I have two Jaeger pocket watches with dials  that are screwed to the movement from the front but this is obviously not a good way to attach enamel dials as chipping would be a problem if extreme care is not used, screws are not usually of a standard set size in cases where I have had missing screws I have a large stock of scrap movements and have usually been able to find a suitable replacements. Buying a replacement pocket watch dial from Cousins is not a option you have because no one makes them now.
Another option you have is to use dial pads which are small adhesive dots that can be used to fix the dial to the movement.
Scaling from your photo of the screw on a Dumont pair of tweezers I estimate the thread diameter to be 0.6mm. If this is corect PM me and I shall mail you a suitable screw. The best way to repair the damaged enamel is to use white UV setting nail varnish now available everwhere and on eBay. You set it in sunlight or under a cheap UV light as used for detecting forged banknotes. Even less expensive UV LED chips can also do the job. Cousins sell a similar UV varnish for dial repair but at 10x the cost.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
