Changing HD MacBook Pro
By any chance have any of you guys changed a HD on a MacBook Pro. Fitting looks easy but what do I do to get it up and running once fitted. I did do a back up in November but is this all I need.
I don't own a Mac but the concept must be the same as pc, once installed you must give the HD format in the "Disk Utilities" (I don't remember the name of the app) search on the web, there must be tons of tutorials to follow.
Connect the new drive to USB (you may need an adapter), use a piece of software called Super Duper to clone your existing drive to the new one.
https://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
Very simple to use but follow the instructions obviously.
Check that the mac can boot the USB drive by holding down Option when booting and choose the USB drive to boot from.
Once confirmed, take the old drive out and put the new drive in.
Done this many times, Super Duper has never let me down.
On a PC the best software for cloning a disk and making it bootable is https://www.easeus.com/
I used it a couple of weeks ago when installing a new SSD to my editing laptop and it was flawless.
5 minutes ago, clockboy said:
It’s not possible to make a bootable disk because the HD is broken
I think it's better that you give it to a shop for OS installation. You could prepare an USB stick yourself using another Mac or  PC, but that can be very time consuming including obtaining and converting installation media, reading how-to's, etc.
1 hour ago, oldhippy said:
Can't you clone or copy an image?
No the MacBook is at present a dead en. I took it to Apple and after several hours they could not get the HD to write so there opinion is it is most likely the HD is the fault. However because it is 6 years old Apple no longer support it which has pissed me off a bit. They have given me a a address of third party company that might be able to help.
Thanks Mark the problem is the HD is not functional I think. So making bootable drives etc is not possible I think. The Guy at Apple formatted the HD and tried to restore but no good. I hate
bloody computers!!!!
Don't hate computers, just learn more about them as you already do for watches. Yes, Hard Disk Drives are not optimal if you want them to last forever, if you want reliability use normal Solid State Drives or even M.2 SSD, they are expensive but they're quicker and last longer.
Tip: don't buy any Mac, they are more restricted in terms of repairing and are just compatible with their on hardware, PC's are more compatible with third party components, they are also more affordable for the same performance.
I used to own PC,s but just got hacked off with constant updates & then periferals such as printers not working etc. So 6 years ago I changed to Mac and this is the first problem.My wife has a PC laptop and it is nothing but trouble slow and a constant flow of updates. The problem now is Mac seem to be  losing their way since Jobs passed on. I have spoken to a third party today and they do a diognostics test for £35 + VAT.
The thing is M.2 SSD haven't been around too long, so regarding how long they last, we don't know.
It's been around for about 6 years, and their reliability resides in the architecture of the m.2 itself, they are even better than normal SSD (SSD mSATA) as they don't need power from the power supply, making them even better is something goes wrong with a discharge.
But my previous point about the difference of HDD and SSD mSATA/SSD M.2 is that the HDD is at constant spinning and this creates a mechanical wear. That's usually the problem with HDD's in general.
You can control the updates and select the ones you want, you can even disable them. But to each their own, I don't like to deal with the over inflated prices of a Mac, I built my own pc on 2014 and just upgraded the graphics card once, I love my pc, never had a real problem with it or a slowdown in performance.
Lets not turn this into a MAC vs PC thread - it wont go anywhere.
If you press command and r on bootup you should get to the recovery console. Then you can restore the backup to a drive connected to USB. Once this is done put the new drive in the MAC.
If you don't feel confident then you are best paying a local computer boffin to do it for you, but really, its not that difficult.
If you have not got a working backup then download Sierra (or High Sierra) and make a USB boot disk (a 16GB thumb drive will do) then put the new drive in and install osx from the USB boot disk - loads of tutorials on the net for this, you should even find a youtube video showing how.
Downside - you will need another computer to make the USB boot disk.
I have taken it to a repair shop and after a quick diagnostic it looks like it is the HD. The guy has recommended fitting a solid state HD instead of re fitting the same. All down to cost now will give an update when it is resolved
M.2 (and NVMe) is just a physical / interface specification. The flash memory modules themselves are the same. Unknown to most, some cells "regularly" fail with wear over the years, but these are transparently remapped to good ones.There is no doubt that flash memory storage is a better purchase, and it has been since years already.
He's correct. To save a little you can shop on the net, Samsung being the technology leader.
Thanks Mark I think that what Apple tried. I have taken it to a boffin recommended by Apple store engineer
@clockboy; I've changed out HDD's a couple of times on my Macbooks, but it has been a while ago. Depending on the age of your Macbook, whether it has a CD drive and came with installation disk, or else you may need to get a bootable USB-stick with OSX on it ...... which OSX depends on what your computer will take, or perhaps better, where it came with ...
Bootable USB's with OSX are available on eBay. You can buy a quality new, I assume 2.5", HDD. Now, from top of my head, once the new HDD is installed, and the bootable CD/USB inserted, press the power button and hold down the "alt" key. It should ask you where you like to boot from and from there follow the instruction. Once the new OSX is installed, you can upgrade to the next OSX. If you have done your last back-up via time-machine on an external HDD, it is easy to re-install you back up.
Every time I found plenty of instructions on the internet and with time-machine it shouldn't be hard to get your Apple back to life..... if it is indeed just the HDD? There is nothing wrong with HDD's and I wouldn't invest in flash-drives.
Last year I bought a brand new Macbook Pro, the last 2012 model to be precise with HDD and CD-drive. Those are the ones you can repair yourself and my 2007 Macbook is still going strong too. So, don't give up without a fight ......
As said, it has been a while since I've done it, but if it is just the HDD, with help of the internet  and a bootable medium, you should be able to get your Mac back on the road without too much pain .....
Suc6 !
Edited by Endeavor
Congratulations ! A 6 years old Mac with an SSD drive !! You better be proud on it, as those old Macbooks are in my opinion superior to the new & far more expensive Macbooks. At least you are able fix it yourself or get it fixed by a boffin. With the newer models that needs to be seen?? I consider myself lucky that I end 2016 could pick up a brand new Macbook Pro A1278, which is a mid-2012 model. It still has, what was at that time normal, all the USB ports, mag-safe, SD-card, ear-phone & "you-name-it" ports. Now you have to pay a lot extra to get a port at all !! Forget about DIY upgrading or repair.
I do agree with you, Apple lost its marbles and I have no idea what to buy next when my Macbook enters the computers prehistoric age. My first 2006 Macbook is now 12 years old, but it's still working on OSX Lion.
Admitting, it needed some DIY surgical interventions / modifications / upgrades.  With a bit of luck, you can enjoy yours for another 5 years or more ! :)
Edited by Endeavor
22 minutes ago, Endeavor said:
Congratulations ! A 6 years old Mac with an SSD drive !! You better be proud on it, as those old Macbooks are in my opinion superior to the new & far more expensive Macbooks. At least you are able fix it yourself or get it fixed by a boffin. With the newer models that needs to be seen?? I consider myself lucky that I end 2016 could pick up a brand new Macbook Pro A1278, which is a mid-2012 model. It still has, what at that time was normal, all the USB ports, mag-safe, SD-card, ear-phone & "you-name-it" ports. Now you have to pay a lot extra to get a port at all !! Forget about DIY upgrading or repair.
I don't see the point in insisting on old HW, and please note that I'm a stingy late technology adopter.
The moment you're hands-on with a current top product, the previous one from more than 2 or 3 yrs ago looks like almost unusable. This has been true form me since the last 35 years including servers, desktops, laptops and smartphones. I never buy top of the line, overpriced latest model, but look instead for good deals with the best price/performance ratio. I find no benefit in pressing on with obsolete hardware, it's not like vintage watches.
Case in question, if you don't like the current Apple hardware offer, get a Thinkpad, Dell, or Asus laptop and install MacOS or you favorite OS on it. Then sell the old one for whatever you can get, or give it away for a good cause, and move on.
The couple of days spent in setting up and learning about the new machine will be well worth with the boost in performance and experience.
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
