My First Staking Set Advice
Hi, Levine:
I could be wrong but my understanding is that there is a piece in the staking kit for punching out the balance staff as well as a piece for re-establishing the rivet once the new staff is in place. I have watched this same procedure done by a couple of different folks on YT and apparently the toughest part is getting the hairspring, et a,l dismounted to remove the broken balance staff.
Time is a craftsman's finest tool, so use as much as you like.
Best Wishes,
Bruce
Anybody ever seen a staking set like this?i got it on eBay. But I’ve looked and looked and never seen this sort. It has five kind of long stumps and 15 or 20 long stakes and also about 10 shorter stakes. No makers name anywhere either I noticed that someone has numbered a few and the rest are just plain. Any input is appreciated.B6AFC254-8EBA-4E61-8B99-5F8FA5C701EB.thumb.jpeg.b185935e25d5a82f693b2867eb0a9002.jpegE5C17EAE-0713-482A-B4A0-26259CC88BE9.thumb.jpeg.51198e9da8412ce566de59f362f3f884.jpeg7AC31CBD-BA9A-493E-927A-BD35AC21595C.thumb.jpeg.876205261fc1477ae6b5c91fac2c2c33.jpeg
I think K&D is the best staking tool, it has so many functions. Luckily I got a set from a retiree.
In addition, I also record some brands, maybe some mistakes, because they are too much.
*(K&D )Kendrick & Davis
West Lake Metalix
C & E MARSHALL
Levin
Vigor
Paramount
G&F
F.R
*Boley
Leinen
Lorch Schmidt
Henry Paulson
Helios
Georg Jacob K. G. Leipzig
Manhora
MKS
GEM
Mascot
FAVORITE
*Bergeon
Horia
*STAR
Seitz
*ESSER
Pearl
GESCo
DRACIP
Bayside
F.LORCH
  • 3 months later...
7 hours ago, ifibrin said:
I have never seen a 4.7mm reamer spindle which could hold reamers/broaches for jewels
P1080640.thumb.JPG.8172ecd3d67f96523f1ab4b722523d8f.JPGP1080641.thumb.JPG.bdfa0b5d0ab26e3950829a0731fe1f17.JPGI
I have one. I have to be honest I can't remember where it came from and it is totally unmarked so I can't tell you much about it. It has a tapered hole that accepts the Seitz reamers, is 4.7mm diameter, and fits my MKS staking frame perfectly. So they do exist.
That looks very useful. Unfortunately, it seems to be quite hard to find! Especially one that fits the Seitz reamers.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
  • 3 months later...
That piece looks like the broach that is part of a set of 4.7mm end mill pivot cutters, like the Bergeon 30007...which Bergeon claims comes with 15 interchangeable pivotal strawberries in hard metal  😀...
https://www.bergeon.swiss/09-polissage-abrasifs-affutage-limes-manches-outils-de-coupe/outils-de-coupe/fraise-a-pivot-pivot/assortiment-de-15-fraises-a-pivots-interchangeables-en-metal-dur.html
Edited by rehajm
1 hour ago, praezis said:
Exactly that is it.
B. also sells a 4.7mm broach with 3 small collets for small drills.
Frank
Curiously enough I have one of those too....
But....
the "strawberry" cutter (top) doesn't fit the carrier (bottom), and the reamer (bottom) doesn't fit the top carrier; they are not interchangeable.
I also have only 1 cutter as well 😐
21 minutes ago, watchweasol said:
Hi LWS   thats one nifty set up   was it one of your Dads.
Yes it was. I do not recall him setting it up on the lathe though.  He had four staking sets and this was one of them.  I set it up on one of my lathes to try it out and it works, but I have never used it on an actual project.
I made a post about it with pictures here.
Edited by LittleWatchShop
  • 2 months later...
Hey boyos. This is 100 bucks on the bay right now. I saw love for g-boley staking sets in the thread but they usually had numbers and i don't see a number for this one. I'm legit not even sure what you do with a staking set as i'm only doing basic services but i am almost certainly going to horology school at this point and i know it's something i'll need. Vintage Boley from a watchmakers estate. There's stakes missing but i'm assuming you can fill in the gaps as you need to. You guys think should i go for it? It looks in good condition and also like something you could probably club a rock to death with and it would still work fine.
Edited by Birbdad
Thats a nice set with the base to reverse the stakes. If its a buy it now then grab it quick. If its up for bids then likely it will 3 x that.
Yikes given the fact i will need a staking set eventually what should my ceiling be on it you think 300 or so?  It is sadly not a buy it now.
EDIT: Bid 200 on it. I see staking sets coming up in random watch repair vids usually involving balance staffs. I should probably start watching vids on them.
Edited by Birbdad
4 minutes ago, Birbdad said:
Yikes given the fact i will need a staking set eventually what should my ceiling be on it you think?
Affraid I'm  no expert on staking sets or their value. I have a Star that was mostly complete that came in at a good price of around £80. But i was very very lucky and here in the UK the price is usually higher than USA.The Boley I'm sure is much better quality than mine. If i  personally was looking again and saw a complete set in good condition, i would be wanting to stop at around £300 but I'm also tight.
Well if i get it and it sucks i'm holding you personally responsible haha
So what do you typically use your staking set for?
Edited by Birbdad
Haha. As far as i know the Boley is a good make but maybe not the best. If i was serious about a career in watch repair i would want the best i could get and in a complete condition.  Plenty here that can advice you much better than i can what to buy . Earlier this week i could kick myself for holding back on price with a very complete production lathe. It went for 50 more than my top bid yet i originally planned to go higher than it sold for 😢.  For starters the staking set will replace you a broken balance staff which is a common issue. I dont think there is anything else that can install one.
Used my set for closing up the hole in the barrel bridge where there is too much play in the barrel arbor/bridge. Worked a treat and really improved amplitude. Chronoglide have an excellent video tutorial (look up 'hammertime' on their youtube channel) on the best way to do this with your staking set.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
