New Project Ut 6498
I got this movement on ebay and have been entertaining making a big wrist watch! Well, I just received the case for it, disassemble the movement and everything is on the way for a good maintenance and an eventual new watch for the collection! Here is a pic.
Thanks Lawson, any dial suggestions I'll definitely consider it since I want this watch to be special. For now I have something in mind but I'm still looking. I also sourced all the screws in blue but I'm looking for good looking ratchet and crown wheels...and maybe the click too. I just don't want to venture into substandard parts.
@Ferdinand -- I'm buying a ready made one but it is taking some time to arrive! The case size is 44mm which accepts a dial of about 38mm, both 0.4 and 0.8 mm high. (It has an adapter ring for this purpose).
@Will -- Nice pilot style watch and nice color choice for the dial. I was looking for a blue one but eventually settle for black because of the print. I have a couple of those Chinese clones, new, that eventually will make it to a case but this one is for my personal use so when I came across this Swiss UT 6498 (before ETA) I decided to restore and "improve" it a little. If I don't break it, I'll get a useable -- and hopefully nice -- watch out of this whole thing!
  • 2 months later...
I had forgotten to come back to show the final product! Well here it is along with a new project finished today Sunday!
Original project:
Today's finished project:
This latest project involved the complete disassembly of the pocket watch from ebay, complete servicing and finally recasing...in a nutshell. Blue screws were added, also I noticed that everything bright/nickel plated came out gold! And this is supposedly a better new phone! Oh well!
Cheers,
Bob
Edited by bobm12
Thank you guys, I appreciate your nice words.
They are working so well I can't believe they are old, fairly-cheap-in-its-time movements! The first one I gave to my mom, she is 94 and still active. She meets with friends and they love the watch, also she looks at the movement very often and I can see she enjoys it. There is no money to pay for that satisfaction.
The other one, I'm taking it to work today!
Cheers,
Bob
  • 4 months later...
Excellent job haratua or is it hata? Like in the watch dial? If so, how did you do it? I'd love to have a dial with the brand BOB (my nick name not my uncle! :)  )
Did you make 1 or 4? They are really quality jobs! Is(are) the 6497(s) Chinese clones? In any case, I love the choice of dial, its color and the hands. Also the choice of strap and the Rolex type pins to hold them. Congratulations on a job well done! Super quality!
Cheers,
Bob
PS. Where did you source the case and the rest of the components? Thanks in advance.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
