Particles on Rolex dial
OCSfan
Wondering whether anyone else had experienced this. I repaired a colleagues Rolex after she smashed it in a fall, serviced, refitted rotor and fitted new glass. The plastic seal that arrived with the Sternkreuzer glass was too thick so I refitted the old seal. Watch us running really well and has been on the wrist for a few weeks but large amounts of debriefs formed on the dial, hands and glass. In inspection it looks like small particles or shavings of plastic, I can only think this us coming from the refitted seal, any thoughts gratefully appreciated.
It would seem to me that it is the result of consistent scraping on something plastic. That would lead me to believe that the outside of the rotor might be scraping on a seal, or?
Great thought but I can’t see the movement being powerful enough to push through causing such debris. I’d expect it to stop, or at the very least speed up significantly while losing amplitude.
May be a good idea to put on timing machine and see what it does.
Cheers
It may be some sort of parallax error, but it looks to me like the luminous dots are smaller on part of the dial. I don't know how long the second hand is, but could it be "off-plane", and chipping off tiny pieces of the luminous as it passes those dots? If the second hand is long enough to hit them, I'd hold it under a light for a while then go into darkness and see if the debris glows. Far-fetched?
It looks to me that the top layer of gloss lacquer on the dial is delaminated from the dial if the seal around the crystal is incorrect and moisture has entered the watch, did you pressure test the watch after fitting the new crystal?. The bezel has been refitted incorrectly any way the hour markers do not line up with the bezel and the double size bezel maker should be at the 12 o'clock postion and not at 9 o'clock as shown  and the gap between dial and rehuat looks too great.
Looking at the watch as it is I would suggest there is no effective seal around the crystal at all.
Edited by wls1971
4 minutes ago, wls1971 said:
It looks to me that the top layer of gloss lacquer on the dial is delaminated from the dial if the seal around the crystal is incorrect and moisture has entered the watch, did you pressure test the watch have fitting the new crystal?. The bezel has been refitted incorrectly any way the hour markers do not line up with the bezel and the double size bezel maker should be at the 12 o'clock postion and not at 9 o'clock as shown  and the gap between dial and rehuat looks too great.
Woops, hadn't noticed that. Now you've pointed out the misalignment it looks awful and I will refit correctly, thank you.
I'm not sure that the debris is getting in, I will check the hands etc, there is mo delamination of the lacquer, just some scratches frothed previous broken glass occurring during her accident.
I'll order a couple of replacement seals and have another go at fitting the glass and bezel (correctly).
Did the previous glass shatter? I’ve seen terrible things happen when glass gets into a movement. But that’s presumably all removed since servicing.
My first guess would have been the auto rotor colliding with something, but I’m not that familiar with the build of these watches.
  • Similar Content
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
