Preventing cracked jewel
Happy New Year, everyone! I hope you all had a great Christmas.
I'm working on an Elgin 554. After disassembly, I inspected the jewels and found the one where the fourth wheel passes through damaged.
I suspect I cracked it when I was removing the second hand connected to the fourth wheel pivot. I think as I was removing the second hand, the shoulder of the pivot pressed on the jewel.
The distortion on the jewel's surface - bent towards the dial side, supports this theory.
Question: I would like to seek your advise - How to remove the subdial hand without breaking the jewel?
I'm thinking, while the dial is still attached, pull the fourth wheel after removing the train bridge. What do you think?
Looking forward to your advise.
Cheers!
Joel
Sent from my ASUS_Z010D using Tapatalk
If the second hand isn't fused to the 4th wheel arbor, it should put that kind of stress on the back of the jewel. If it is fused, and can't be coaxed off the arbor without stressing jewel, maybe you could put a drop of thin oil, penetrant, on the top of the second hand, where the arbor passes. Maybe that would loosen the bond to make removal easier. That said, again, under normal circumstances, it shouldn't be that hard to remove the second hand. Good luck.
Thanks for the advice!
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
