Lubricants
Well I would definitely start with Moebius 9010 (for train wheels and balance endstones) and 9020 (for train wheels) if you are working on Pocket Watches.
Moebius 9415 is a must for Pallet/Escape wheel teeth.
A quality silicon grease.
Moebius D5 is essential (barrel arbor, motion work).
Molycote DX or Moebius 9501 grease for keyless work.
Moebius 9501 or 9504 for high friction (e.g. Cannon pinion, Setting lever spring and anything at high friction).
Moebius 8200 grease for mainspring. Moebius 8217 for barrel wall (automatic watches)
It's a lot but at a minimum get 9010, 9415, D5 and 8200
I hope this helps.
Recommended Lubricants for Getting Started.pdf
Moebius_Oil_Chart.pdf
  • Like 25
About a year ago when I was just starting to get a bit serious about starting this hobby I bought one of those cheap watch repair kits. I have since replaced all the crap in there with quality versions of what they were supposed to be. My question relating to this topic is this little tube of oil in the kit. Is this just more junk from the kit or does it have any purpose or can it be used in place of any of Marks suggestions? Seems VERY light and my feeling is that the trash can is its new place.
I would not trust it. The last thing you want is for oil to spread out of where it is intended to be.
Its probably still good for some things though. I use cheap clock oil for lubricating my tools like my lathe, the threads on pin vices etc.
  • 2 months later...
I have watched the video on how to service a 2824 movement. I have movement here that I would like to service, but I have a question about the oils.
In the video, (Mark's video on youtube) he says to use Moebius 9010, 9415, and D5. I am a real amateur and I have to buy all the tools and oils to do this. My question is if there are any oils which I can substitute in place of these to use as a cost savings, or If I haveto go with the Moebius oils.
Any help would be greatly appreciated. Also, I am in the USA, so if any of the sites in the UK dont ship overseas, or if its not worth it, please let me know.
Thanks,
Guy
Hi,
It is most desirable to use the best oils possible especially when working on high grade watches. I regret that this is one area where you should not skimp.
I agree that Moebius oils are very expensive though.
For the grease you can use Molycote DX which is really quite cheap.
If you are just practicing on scrap movements then you should be able to get away with Moly (grease), and 9010 and a heavier clock oil for the barrel arbor bearing.
If you are very careful you can use 9010 on the pallets in place of 9415.
But this is not a desirable solution on high grade movements as poor lubrication will cause poor watch performance and even stop a watch - I have seen it time and time again.
I hope this helps.
Hey DWDrummer,
I just noticed you are in KC. I am in Overland Park. What watch shop do you use? I am VERY new to the hobby myself. I have been collecting tools, reading blog posts, and reading Henry Fried's bible. I an currently going through the http://www.clockmaker.com.au/diy_seiko_7s26/ tutorial. I have taken a perfectly functioning Seiko and turned it into a pile of parts! I am waiting for L&R cleaning fluids to arrive so I can clean the parts and move forward.
At any rate didn't intend to hijack your thread just wanted to connect with a local amateur watchmaker. In the future maybe we could split costs on things?
Regards,
Alec
I hope this helps.
Is this acceptable for Molycote Dx??
http://www.amazon.com/gp/product/B00CAD6AAE/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A8FEBY5XL3B8V
Thanks,
Alec
Is Moebius 9501 acceptable for the mainspring? As I don't have 8200
Will I do damage to the mainspring by using 9501; or is it just due to the cost difference between the two that 8200 is the choice?
Hello, I'm a new member, I'm a lot into watches but with little experience. Still I think I can answer the last 2 posts. Please, feel free to disagree since this is all a learning experience.
To Alec:
I think the problem with the substitution might be a "spreading" effect potentially contaminating other parts in the mechanism. Oils designed for watches are supposed to stay in place. By using that molycote substitute you may be risking its interaction with other oils in the movement causing contamination resulting in decline of efficiency or worst. With that said, it would be interesting to consult the manufacturer and/or try it in a test watch and see what happens! It is my experience that a lot of products out there, sold as specialized items, come from widely available standards used in far related fields.
To Lawson:
Even though I have yet to experiment with other oils/greases including that one, I believe the Moebious 9501 is a synthetic grease used to alleviate friction problems. Normally we use "breaking" type grease in the main spring. This means that a certain friction is welcome inside the drum if I can put it that way for short. With that said, I don't think it will damage anything but make the mainspring slip and not work properly. This translates in a loss of power. In other words, your reserve may be less than optimal....
Happy watchmaking,
Robert
Dwdrummer, isn't Eurotool a brand Horotec endorses? I remember something I got from them made by eurotool...I think. In any case, I agree with watchrepairguy!
Happy watchmaking,
Robert
I think I finally cracked the Seiko oil equivalents according to their charts for 7S26/7S36:
Moebius A = Moebius 9010
S-4 = 8302
S-6 = KT22
Please, correct me if I'm wrong. Thanks,
Robert
Edited by bobm12
I know this link is getting old but I just found Seiko's S-4 and S-6 lubricants and they are not one bit similar to the ETA thought to be their counterparts/substitutes. Here are some pictures:
S-4 for barrel spring and some related parts (the black thing you find when you open those Seiko 5 barretls)
For keyless works and related: (anything requiring thicker oil than Moebius 9010)
Needless to say that Moebius 9010 is the lighter oil recommended Seiko call it Moebius A. It also uses it to lube the pallet fork jewels! (rather than Moebius 941!
In any case, if working on Seiko's these could be the only lube needed. If working with Swiss movements then oil needs will vary according to different brands even if they are based on ETA ebouchees. (Also the size of the ligne will influence the type of oil use)
Anyway, I hope this can help when choosing oils.
Robert
  • 4 weeks later...
Since Molykote DX can be substituted for 9501 for keyless work, can it also be substituted for 9501 on the cannon pinion and setting lever spring? The reason I ask is I'm trying to keep costs down and 9501 isn't cheap.
Thanks,
Don
I hope this helps.
Thanks,
Don
Keyless work includes the setting lever spring ;)
Moly should be fine with the cannon pinion although I have never used it for such I can see no reason why it would not be affective :)
I've seen this topic come up all the time in various forums, but somehow I'm still not clear on the greases. I'm starting from the charts for the Valjoux 7750, and will be doing various automatics, chronographs, divers/pilots.
9010        fine oil
9415        special oil for pallet stones
9104 (= HP1300)   thick oil (instead of D5)
9501      for driver cannon pinion, keyless works (instead of Molykote DX)
8217 (=Glissalube 20) for (automatic) barrel wall (instead of Kluber P125, which I can't get in small/cheap enough quantities).
Should I also get 8141 for the mainspring itself and the barrel floor ?
Is that OK?
I figure  that given the amount of oil we use in a watch -- we average hobbyists -- once we get some basic stock of the most useful oils -- sometimes making them do double duty in a pinch -- we are set for a big while. In the meantime, we can start stocking up on the other oils -- little by little -- so in the end we can service any watch with the proper lubricant. One thing to keep an eye on is the expiration date vs. how much we use them. It is a shame to have to throw out expired oil! So, as it goes, Moebius 9501 is next in my list! In the meantime, DX and others will have to double duty for it.
On a happy note for those on a very strict budget, Novostar type B can be used instead of Moebius 9010. I don't do this but I do have a bottle in my "traveling tool kit" instead of the more expensive 9010 which stays at home.
Edited by bobm12
OK, I ordered the following Moebius lubricants:
9010
9415
9104
9501
8217
8141
1 ml of each, except the last two, which were 5 ml. Total, just under 100 €.
I've got a silicone grease in the O-ring sponge cleaner/applicator.
Re HP 500: I was looking to get fewer oils/greases, not more :-)
By the way, a tip from photography film development: you can increase the shelf-life of chemicals (oils) which are prone to oxidation by adding small glass beads which displace the air from the container.
Oh, that takes me back! The marbles were made redundant when polythene bottles came out because you could squeeze them.
This topic is now closed to further replies.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
