The Joy of Building a Watch
This project started more than a year ago when a friend gave me his gold-plated 6309-7040 case. Just the case, the crown and the bezel.
Now, I really don't fancy gold watches but the thought of pulling this off to something that I will actually wear excited me.
So I attended to this project whenever I had the time.
Started off by buying all the parts that I needed including the crystal, the crystal ring holder, gaskets and the two-part stem. These are all after-markets and are readily available here in the Philippines.
But the movement ring and spring as well as the case back, I have to acquire from ebay.
The real challenge however is deciding on the look. Gold hands and gold-black bezel inserts are available. But I don't think it will look good to use the available dial and chapter ring.
So I had a local watchmaker custom made the dial and chapter ring with my desired color scheme.
(To be continued)bce9ec04ed1089dea89f4d1a1ef07dee.jpg8ff03b56537bba07baf7d3b0e98eca45.jpgfe21ac83af82c75574a98bfcc621ad70.jpg
Sent from my ASUS_Z010D using Tapatalk
My wife thinks the case is too loud, especially with its cushion case. So I thought of using a brown leather strap to temper it's look.
I use a 2mm brown leather and brown stitching for the strap. I wanted to give it a rough look so I just burnished the edges a little
(To be continued)714c095f85f3aecd2da190969225ec22.jpgd243161c3f4fdef3544189dec780bc79.jpgd47151e6b0eba95dd42809ddd229d9ae.jpgf5632728ea04e6287979570f0c7bd1d9.jpge480e40f1713ea5bcb516dd5473b248b.jpg
28 minutes ago, Ishima said:
Really nice work. If i were just to nitpick a little though, theoretically you're not meant to set hands in the movement holder, doubt its a problem for a sturdy movement like this though.
That's perfectly fine with Seiko. There is no way to "support the jewel" as you often read, whatever that means. .
Yeah, i really don't see a problem with this particular movement.
The idea is that you rest the watch on the bench when pressing hands which prevents gear train bridges, that might be flimsy enough (so mostly quartz i suppose -- I was first trained on quartz so this was an early lesson for me) from flexing as you press on the seconds hand, which it can do if suspended above a surface and can't do if rested or 'supported' against a surface (e.g your bench)
That's interesting- I never would have guess that.  My preference is to put the hands on with the movement already in the case although that's not always possible.  I've not knocked out a jewel yet or bent any wheels or plates though.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
