Has anyone used this software? "PC-Zeitwaage"
ArtNalika
  • 2 years later...
from this web site
http://pczw.uhren-mikl.com/index.php?Demo
I want a full version but I can not contact to seller
What should I do. Can someone give me a copy of the program?
Hi. I have also done tests with the program and I find it very good. However, like you I have not been able to contact the creator although he uses the social network on instagram. I would like to have the program in English or maybe even in Spanish which is my mother tongue.
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
