Removing rusty screw from mainplate
YuriyV
Very often one or more screws are rusty to impossible safely remove them from the place. Usually apply to bridge and dial screws.
What are recommended measures to remove them without damaging other parts?
I'd narrow down my question to three typical scenarios:
1. Many parts remain on place including the dial. And other parts, hidden under it;
2. Dial and other parts removed. But MS barrel and/or gears are still under blocked bridge(s );
3. Everything is removed, including all bridges, but some non removable steel parts (like springs) are still on place;
Thanks!
Alum in warm water or a screw extractor, you can use the search box top right to find related discussions . However I would first apply some penetrating oil and try to unscrew first, even if that shears the head, because there will be less material to dissolve, and you can remove the other parts.
As a sidebar, alum in boiler water is an old trick to remove a broken tap if its broken in AL or a copper alloy (non ferrous).  After a few hours it turns the tap into sludge.
Boiling and hours is a lot harsher treatment than JDM recommends, so a shorter soak might be just the thing to eat up enough of the expanded iron oxide to free things up.
The point though is alum can dissolves steel quite effectively so try to keep other bits of ferrous out of the mix and if they have to be there, don't leave it on the stove overnight with other bit of ferrous metal still attached :)
Edited by measuretwice
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
