Loupe / eyeglass / eyepiece
Hi guys
i am about to start on replacing balance staffs and jewels over the next couple of months. I noticed in marks video on replacing staffs he use a eyeglass to check the rivet is ok.
I have just tried my old eyeglass its a x7 and a x10 and they seem the same to me, To get any kind of vision through the x7 you need to be near enough to be touching what you want to view with the eyeglass and then the view is not big enough. so i used the x10 and its bigger from the same position than the x7 (nearness) but blurred as to be know use. so if i move back to get a clear view its just the same magnification as the x7 just further away.
So what am i missing and is there a solution.  more magnification x20 x40?
cheers
gary
46 minutes ago, gary17 said:
Hi guys
cheers
gary
I have used these for years, x10 to start and x25 to finish teh pivots. Cheap and effective. I also remove one side for work where i am no afraid of scards of metal from the lathe.  Check out my lathe videos.
There is a lot of difference between one manufacturer's x10 and another's. Same goes for any other magnification. In my experience, the whole thing is a bit of a minefield. You buy a handful of different magnifications, and discard the ones which are no use for one reason  or another, then guard the good ones with your life, whatever x-factor is written on the box.
My favorite hi power loupes are Asco aplanetic (the achromats are awesome too). They aren't cheap but they're goood. I use them mostly for checking positioning of staffs on the jacot tool, or a quick check of things at the bench that don't warrant shifting to the microscope.  10x most of the time, 12x sometimes. There are loupes to 20x or more but I think they are a vestige of a time when binocular scopes in the 7-30x range were rare and expensive. I think somewhere I have a 30x loupe but I just got it as a curiosity.
I wouldn't work with one though, just for inspection. I've had a microscope over my lathe since I was in school last century, literally couldn't work without it. Ain't no loupe gonna help cutting a Piaget 9P staff at 1.60mm total length haha.
http://www.schurch-asco.com/e-shop/catalog/index.php?cPath=114_115_226&osCsid=604fcd0e090a4d4fefae3feb8ce1c5b6
1 hour ago, jdrichard said:
These ones...forgot the picture
so you close one eye or the other back and forth? do your eyes get tired from this?
are they really that much clearer, or less distortion that a non aplantic loupe? curious about that..
I really notice a difference, they just have a nicer undistorted image. In the Schurch catalog they have their H2 loupes that look like regular loupes but are double lens and 10 or 14x; though they have larger lenses I find the distorted field around the central view pretty distracting and uncomfortable for the eye.
I have two every day loupes for general work that I go back and forth with, both were made by Wild Heerbrug who unfortanately don't make loupes like this anymore. One is a 3x simple double convex lens, the other a 5x with a pair of plano-convex lenses. Not many makers bothered to use a pair of lenses for 5x; I don't know if it's a true aplanatic but the image is great. Most of the time I just stick with the 3x.
  • jdm changed the title to Loupe / eyeglass / eyepiece
  • jdm pinned this topic
I use a microscope for jewels also.  Outside of that, I kinda built up my supplies on a shoestring budget.  I have some strong reading glasses for when I just need to see what I'm doing close-up. I also have a headset magnifier that Sarah got for me. I have a couple triplet loupes in my tool chest. But, this'll sound weird, the magnifier I seem to grab the most is a little lens array that I salvaged from an old video recorder. It's even more powerful than any loupe I have. I can even make out cracks in jewels (but I still use the microscope for a better look). It's ideal for initial inspections.  But generally, with my astigmatism and other eye issues, I like to keep a variety of things around and grab whichever one I need to, so as to get the view I desire.  I need lots of options.
I may have to give a serious look. As I mentioned elsewhere, I always seem to be on a perpetual hunt for the perfect loupe, because my eyes have well... kept up with my age. True they are expensive but if it's the last one I would own, to me it's worth it.
4 hours ago, rodabod said:
I find they are a bit like tweezers - you have to try several. Nowadays I mainly use an AF branded loupe for coarse work.
Peak microscope with 100x eyepiece for pivot/jewel work.
Yes, it depends on everyone's needs and comfort. I did those before :
1- Ordered 4x and 10x from Aliexpress. Very cheap, magnification of 10x feel like 5x and glass has some staining on the reflective coating.
2- Ordered an 4x aluminium and 10x H1 directly from Asco. They are great compared to the cheap ones but still struggling to use it comfortably with loupe holder.
3- While ordering a bunch of tools and supplies at a canadian material house, I stumbled on clip-on loupes which isn't expensive so I ordered a 4x clip-on. I also bought a 3.5x reading glasses at a drugstore. This is my perfect setup and view is great (3.5x glasses is good by itself for general work and with the 4x, I can get close enough even on the tiniest parts. I still use the Asco 10x for closer inspection.
4- I also bought a cheap electronic microscope from Amazon and while magnification is good enough, handling and illumination is something i really struggle as I need to look on my iPad for the view and the direction seems reversed both ways, making it hard to coordinate hand-eye movement under it.
I'm currently thinking about buying a stereo microscope for inspection to replace the cheap electronic microscope. Not sure which one is a good option.
This might just be true for me also. We'll see. Excuse unintended pun.
So, after this conversation, I went ahead and purchased a Bergeon aplantic from ofrei, 4X at 2.5" and yes, there is noticeably less outer view distortion with it. not bad. not bad at all. I've swapped it out with a regular loupe and use it now with a holder ring and is in my regular rotation of loupes, cheaters with clip-ons, mag visors and my scope lol. I think I'll wind up being "that guy" with a huge collection of loupes all over the place, using one for this, one for that...
one thing I do do though, is drill tiny holes all around the periphery. not many, just a few. it helps a great deal with relieving the fog build up I seem to get all the time. I have one that came with a large opening but I'm not a fan. it's distracting. but the tiny holes work for me.
thanks for the aplantic tip. I might look into others.
I only use them to check alignment while using punches & staking tool as it's almost (ALMOST) impossible to use microscope in such cases. But still possible ?
Lol the only thing i use my scope for is inspection. I can't fit everything under there and I sure as heck haven't mastered the art of hand-to-eye-thru-microscope thingy yet lol?
You mess with your lume project yet?
It depends on the microscope - some probably are not so good, or simply not suitable for watch repair. My Meiji with light is amazing for watch repair related tasks.
No, not yet, as i've decided to leave my Omega as-is, and i do not have any other candidates to experiment with lume. Besides, i have finally received my "lost" parcels almost 6 weeks after ordering them from UK. I don't want to order anything before Christmas & New Year as it will take forever thanks to "speedy" Mail service. I have a joke about Royal Mail & Canada Post, but it's still in-transit between UK and Canada.. ?
It's not looking good for the home team either. The Hampden jewels are still lost in space and was even sent a second pair, with no sign of them.
Hey good choice on the Omega! Kudos!
  • 2 months later...
Dear all,
for me wearing glasses one of the best designs for a watchmaker's loupe is the old English style. Two lenses - 50 and 100mm focal length - that can be swung into place before the spectacle lens. Three magnifications at your fingertips. Cousins sells those.
89164193_Screenshot_2021-03-07-15-43-21-491_com.opera.browser01.thumb.jpg.ff87bfbcc113b129d028da91e3a94b2e.jpg
However those are so cheaply made there's no joy using them. Cheap lenses, cheap mechanics, flimsy clip. Does anyone know of a brand that makes them the proper way?
Thanks and all the best from Hamburg
Alex
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
