Loupe / eyeglass / eyepiece
OK, several things to say here. The thought thay if with the old spring the movement works 16 hours, then replacing the spring will solve that - is totally wrong. With a new spring the movement probably will work for 17 hours. The power reserve is practically not reduced when the spring gets weak with the age. It is rather something wrong with the movement. As You worked on the hairspring, we need to confirm that it is OK now before everything else. So, thake the lever out and do the free oscillations test. What is the result? I expect numbers, not only 'it is good' or 'it is not good'. Then, this is no jewels pin lever movement, so this is not unusual to have not well regulated or even worn escapement, this is the main reason that this kind of watches doesn't work as long and reliable as the jeweled escapement ones. You can find many of them with no wear at the crown and case, and this is because they stopped working normally pritty soon after purchase. -
Welcome 🙂 Inherited watches are very tricky. Some of them, or all, do have sentimental value, perhaps not to you but perhaps to others in the family. Ruining them doesn't make you popular. Start on innocent watches who do no harm, not to your wallet nor to others 😉 BTW; for in the future it would be helpful to others to mention your location in your profile. Success 🤗
Hello from the Mid-Atlantic United States. I've been in the hobby for a few months and have concluded that I will be staying in it for a while. I've started to get some proper tools and I am looking forward to developing some skills. My current goal is to get comfortable enough to service / repair some watches I've inherited from family members. My current project is a Mentor pendent watch with a BF866 movement that belonged to my great aunt.
