SONA/CITIZEN
33 minutes ago, berniethebolt said:
does anyone know which citizen model the hmt sona is based?
I don't think that HMT based any of their watch models on any Citizen models as such.
However, I do know that HMT used the Citizen Cal:0201, made under licence and re-branded, in a lot of their 17J manual wind watches.
Post a pic of the movement and I may be able to identify it.
OK MARC.DID YOU GET MY PHOTOS?
Bernie,
comparing your pics with my own Ciitizen 0201 it looks as though there are some minor differences in the shape of the plates and machined recesses, but all the key reference points look the same.
These are Citizen 0201 for comparison;
P1060273.thumb.JPG.c46dfc2f5fb6e512472675d83d0d5c79.JPGP1060277.thumb.JPG.3962d864935e72b56ea5203ec87fe751.JPG
The part you are after is the hour wheel. If you measure the dimensions of yours I can tell you how they compare with the Citizen.
OK, I'm not sure that the hour wheels are interchangable then. On my Citizen 0201's the hour wheel is 6.55mm diameter (32 teeth), with a 1.53mm OD pipe, 1.27mm tall. I have also just opened up my HMT Jawan which does have the HMT version of the 0201 movement and the plates are identical to the Citizen, so I'm not at all sure.
As for the keyless works, have you had them apart? It looks to me that the parts I've edged in blue might be in upside down. If you flip them over and add the missing parts I think they will look the same.
5a33f0d588eb3_2017-12-1515_42_41.thumb.jpg.ae5a04598a4970d64c45197cf4755e56.jpg.29114f152901c06b3960cb2bf4312c8f.jpg
Slightly clearer
Edited by Marc
clearer pic
ok, this link shows a HMT movement with the same shape plates as yours;
http://jayprashanth.blogspot.co.uk/2008/02/indian-mechanical-watches.html
and identifies it as a HMT 0231
Ranfft;
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk&HMT_0231
says that the 0231 is a copy of the Citizen 1802 BUT.... the pic he shows has the same shape plates as my 0201, and the dial side is totally different, so somewhat confusing.
one posibility is that HMT used different shaped plates at different times for the same calibre and it is a 0201, can you remeasure your hour wheel, make sure that the calipers are properly zeroed first just to be sure.
One thing that Ranfft does say is that the cal number may be on the case back. Also have a good look over the main plate and make sure that there are no numbers there.
OK,ON THE CASE BACK IT DOES SAY 0231.i get around 6.40 dia.the other meas.are similar but like i said my calipers are playing up.as for the keyless works you are probably right as i copied the routine off my phone camera,so that can be soon sorted.thanks for that.the hour wheel would probably have had 32 teeth before i sheared them off as i counted the remainder and the gap would allow for those missing!B.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
