Early AS 976
Watchfixr
Had a very early AS 976 come in for service. I mean very early, blued steel hairspring and no cap jewel on the bridge escape wheel pivot. Put a little pressure on the 2nd wheel and it started to tick, so it needed service. I disassembled it, ran it through the ultrasonic, reassembled and lubricated. I always do a preliminary time and amplitude test before putting on the cannon pinion just in case I need to tear it down for some reason. Dial down, 276 degrees amplitude and 4 seconds fast. Dial up, it stopped! Repeated tests. Again, 276 degrees and 4 seconds fast dial down; stopped, dial up. Now, I know what is wrong, but I want opinions from the gallery. I figured it out in the middle of the night after I had stopped at that point. It is simple and easily missed!
Anyone want to offer an answer?
Ok, a lot of good thoughts. The end shake of the balance was ok. That's what baffled me.
The cause of the problem is the very end of the cock pivot is broken off. I missed it during examination of the wheels and pivots. Too complacent! With a high power loupe you can see the pivot is broken. the end shake was good because the remaining part of the pivot would fit into the hole jewel far enough to limit the shake. It also was long enough to allow good amplitude and timing when the balance was running on the other pivot (dial down). When I  inverted the movement, the pivot would bind because it is too short to reach the cap jewel.
This problem is somewhat rare, but I thought I would pass it along as a lesson for others. We never stop learning in this business.
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
