End stone problem.
WildBill
Hi, I was in the process of oiling the end stones, I didn't realise they were in two pieces, and I have lost one, maybe its possible to get a replacement..
The top shock absorber went OK, although I found it very difficult to do..."Being the first time" When doing the bottom shock absorber I lost the flat one,
I  also broke the small retaining clip....realising this is going to a nightmare of a job to do....Advise Please.
  • Confused 1
Everyone's favorite job, replacing shock springs. I hope you're up for a challenge.:D
Sometimes the endstone for the top shock absorber is thicker (taller) than the one on the bottom shock block. keep that it mind or you might just break some more shock springs trying to close them back up.
We should be able to help you out once we get that information rogart mentioned.
Looks like you are in luck. For the ST96, you can order the incabloc settings and the stones and springs from Cousins
https://www.cousinsuk.com/category/st-movement-parts
https://www.cousinsuk.com/PDF/categories/1305_Incabloc By Factory - Standard.pdf
https://www.cousinsuk.com/product/inca-end-stones?code=INCA12111
The inca catalogue is in French to make it all more exciting, so Bloc Dessus = Upper complete block (the one in the balance cock), Bloc Dessous = Lower complete block (the one in the main plate). Pierre = stone and Ressort = spring.
121.11 is the upper shock (dessus) end stone, the lower (dessous), in the main plate, would be 722.11. Just type 722.11 into the Cousins search box.
As mentioned above you may have broken the spring by trying to fit the wrong jewel or fit it upside down, so be sure you get this right.
Lots more info on the inca website here, http://www.incabloc.ch/en/huilage.php but I can’t see the jewel sizes to measure up your end stones and check.
1 hour ago, WildBill said:
Is that it Inca 122.11- highlighted in yellow, that's the lower shock on main plate.? so looking forward to
putting the spring in "not"...will order it today...thanks for help....
Putting those springs in is one of the trickier tasks - I really struggled when I started. I found it useful to use Rodico. Put some above where the spring is to go, stick the spring on to the Rodico, and slide it down.
I have contacted Cousins requesting 722.11 for a FF ST 96... The lower shock stone spring got broke trying to them out, the spring looked fatigued and in poor condition, I just helped it on its way..   Am I right  the jewel is in 2 parts 1 part  stay in its retainer, the other part that you oil that goes on top, and the spring keeps it in place.
Yes, have a look at this (what is shown as 'The Mobile Bushing with it's jewel' is one piece')
Edited by mikepilk
32 minutes ago, WildBill said:
I have to get the broken piece out yet.....its it just fitted into a slot, so it should just pull out with tweezers....."Hopefully"
To get the spring out you may have to push the setting out a bit to free the slot.
The whole setting is out already I think , just the piece of broken spring remains...
Don't know how I'm going to see what I'm doing....I have only cheep loops the most powerful one is 15. just had a look at the broken
spring my finest tweezers seem far to big, might have to do a job on them.
Hi Stuart, I managed to get the end stones for my ST Movement, I don't know how you find the right number ie 722.11 for the lower end stone...My question is I need a spring as well but know the right one to get, can you tell me code no. of the one I need ...Also I must mention on getting out the broken spring, (not even sure if I've got it out) I may have damaged the area where the spring goes.
Apart from getting another Main plate complete with the jewel in place...Do I have any other options,.?
You can identify the individual parts from this table: http://www.incabloc.ch/en/systeme_incabloc.php
So you will see 722.11 on the row for ST 96 under the column headed “pierre de contre pivot dessous”. If you need the spring for the same fitting it would be “ressort de contre pivot dessous”, which is 770.03
If you have damaged the area where the spring goes, then that is the “bloc”, which can be replaced by removing the u shaped clip from the other side of the plate. The nomenclature for the spareable parts is here:
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
