  • 1
Ishima
Vote up function
Question
Just a quick mention/reminder (and im sure many of you don't need this) since I noticed recently that the forum has this 'vote up' for best answer function on the left hand side of any given reply, and it seems to go unused almost all the time, people 'like' posts often, but alternatively/additionally you can vote it up and make it 'the best answer'.
Share this post
Link to post
8 answers to this question
  • 6
I personally would love members to use this feature.
1st it places the most voted answer at the top. Very useful in a long thread for readers to find the most sensible answer.
2nd it gives a pat on the back to the person or persons who took the time and trouble to answer the OP’s question.
3rd it helps to build the community by showing that we care about what others have posted. That’s not a bad thing at all.
So come on guys (and gals) let’s use this facility when a good answer has been posted - it just takes a split second to do and it really can make that section of the forum much much more helpful for others too.
Share this post
Link to post
  • 0
Yes, there is such a feature, but correctly is enabled only on the "repair help" section. And I think the only one entitled to use it should be the OP. The likes and other feeling voting largely surpasses it, so I think it's no surprise that people doesn't use it much at all, and personally wouldn't mind doing away with it.
[EDIT: after reading Mark's explanation below I also support to use voting, as it helps highlighting the best answer as a reference for future readers.
Share this post
Link to post
  • 0
The voting function seems to be a standard part of this (typical) forum software, and I've seen it on other boards as well. I've never used it and most other members have obviously never used it as well!
I personally don't think it's of much use on a forum like this one, with often less than simplistic answers to questions. It's probably used more on forums which ask things like, "What's the best guitar in the whole world?" - and then invites a vote. However, whether the function stays or goes is up to Mark - perhaps we could vote on it... :-)
Share this post
Link to post
  • 0
That is the poll feature actually. It's not enabled here.
Share this post
Link to post
Answer this question...
Loading...
    • Hi Watcheasol,  It's just a number 23124326 or something - its a serial number. Cheers
    • Just guessing here, but maybe it's from some kind of sealed timing device, for competitions, like pigeon racing or something.
    • The way you're supposed to think of cleaning is that all of it is cleaning. the first bath has chemicals to dissolve the oils Remove oxides make the plates bright put things into the solution make things clean overly simplistic probably but it cleans. The rinse also continues to dissolve things into the solution and is technically cleaning. The other thing it is doing is reducing the concentration of the original solution. Which is why typically a cleaning solution followed by two separate rinses unless looking at the modern machines that might have three rinses. If you notice up above nickelsilver Posted that he's using isopropyl alcohol is his rinse actually has two of them. Then looks like were similar for clocks in that I use a commercial solution and follow up with hot running water then immediately in the alcohol. But I still don't have enough experience I've only cleaned a couple of clocks. Then it looks like the demineralized and distilled water is basically just really really clean water. Depending upon where you live the quality of water and its impurities plus the fluorides chlorine might be a problem. Then as far as ultrasonic goes it really doesn't have to be fancy. I started off with a small machine purchased from the drugstore don't think it cost very much money has really surprise was like why Outlook it's 20 and $30 like a century ago or something. Specifically designed where you're supposed to put a beaker into the ultrasonic which today everybody frowns on you shouldn't have anything directly on top of the transducer there should be a separation as bad things will supposedly happen. Except that machine ran for I don't even remember how many years a lot of years before it finally disintegrated. So it didn't seem to suffer any problems of having a beaker directly on top and then surrounded by water to couple the energy. Now if you scroll down the page at the link below I'm using a bigger ultrasonic and to keep everybody happy  and not fuss the beaker is on something above the transducers surrounded by water. https://www.watchrepairtalk.com/topic/285-ultrasonic-cleaners/page/4/?tab=comments#comment-33803
    • Yes, It is very helpful in determining authentic GI issue watches. There seems to be a cottage industry of fake military watches. Mine is 100% authentic thankfully. I do wish I had the original carboard box it came in. I nearly manufactured one from scratch, but I gave up when I saw the work involved, lol. BTW... The photo I posted of the dial looks awful... Specs of dust on the Crystal   That's better!
    • Please see my reply to Marc below My watch and rim lever is very clear on YouTube video
