Cant adjust time
fire
Trying to get my wifes Raymond Weil watch up and running, I have changed the battery and it is now running, The date also changes ok.
However the crown should come out 1 stop for date (which it does) and 2 stops for time change. I cannot get it to come out to the 2nd stop and I dont want to force it.
Thoughts anyone?  My limitations to date are replacing batteries and straps.
Check the position of the caseback, if it's crooked or upside down or anything like that then the groove inside isn't lining up with the stem and that can cause issues like this. Consider having a watch technician maintain this watch in the future.
Edited by Ishima
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
